Help to buy a kit
  • Roberto28
    • Nov 2015
    • 2
    Help to buy a kit
    I am a new amateur of RC submarines, but my knowledge about this matter is very little. Today, I do not own a RC sub. I would like convert to RC one model, e.g. U-Boat Type XXI 1/144 or U-Boat Type XXIII 1/72 or USS Gato 1/144. I like the aesthetics of these subs (WWII) and the size (length 20” or less).
    I thought to buy a 1.25" Single/Dual Prop Static Diver Sub-driver Kit; is this kit good for the mentioned models? I suppose this kit permit the static immersion, control of the propulsion motor, control of the rudder and control of the flaps; is this correct? Is it sufficient a receiver with 6 channels for all functions?
    Besides, I think that it is necessary complete the kit with others items; I seem is necessary buy the propellers, the transmitter (I think it is not include in the kit) or others parts… Please, I need help about how to complete the kit; I would like you give me a list with all the items I need for the complete conversion.
    Thank you very much. Best regards,
    • 13998
    1/144 is too small for a first boat. What kind of r/c vehicle experience do you have?
      Agreed, the 1/144 scale is far too fiddly. The ONLY boat that is easy to do, in my opinion, is the Moebius Skipjack, which is injection molded (accurate) and designed specifically for r/c by Mr M.
      It turns on a dime, is an inexpensive model requiring no hacking of the fuselage to convert to r/c. It's also well documented.
      Get the EASY Sub-driver and you've got the perfect starter kit - but with racy, performance.
        • 3767
        Roberto,
        Welcome. Small amplifies the frustration level. Get a Revell 1/72 Skipjack (or Moebius Skipjack mentioned above). There is PLENTY of room to stuff all the electronics in AND you get an outstanding performing sub. I have built this sub and it is a pleasure to drive (even in a pool). When you get into 1/144 scale you will be stuffing 10 pounds of electronics into a 5 pound bag (or tube if you will).
          Well said Tom
          • QuarterMaster
            • Sep 2015
            • 1244
            Take a serious look at the BLUEBACK as well. A serious thought out model in terms of construction, assembly, operation, and best of all ease of ownership. No need to alter an existing kit with additional H/W. After building both Kit's and scratch over the years, this would be my choice. I have the original "Manley" version, so I would think Sub Drivers re-release improves on an already excellent kit. Plus I believe there's a nice offer for the first 3, so grab it while you can.
            "Sub" Ed
            v/r "Sub" Ed
            • Roberto28
              • Nov 2015
              • 2
              Dear friends,
              As answer to the question, I have experience only with land vehicles, such as little buggies RC models. But I always loved the subs. When I was 12, I tried build a little sub with a Nautilus model of Revell, but only knew put in it a propulsion motor (old shaver) and handmade rudder (old electromagnet), to drive in surface with a thin wire electric control… It worked well, but was very primitive. I did not have money to buy equipment.
              I appreciate very much your recommendations. I have seen the Moebius Skipjack model in the WEB; it is a very nice model without doubts. I understand you gave me the better help.
              However, I would like own a little RC model (20” or less); I do not know why would be very difficult to build this model…, I have patient and time… Then, eventually, I would want to know the kit I need.
              Thank you very much. Regards,
                • 13998
                Originally posted by Roberto28
                Dear friends,
                Not enough experience. Put together a three-channel model ship -- one that demands some scratch-building experience. Get that working and get used to the job of check-out, maintenance and repair before you jump in with your first r/c submarine. You're not ready.
                  1/144 KILO with EZ driver.
                  • vital.spark
                    • May 2010
                    • 312
                    A 1/144 Trumpeter Kilo of Seawolf. I built the Seawolf as my first sub with no RC experiance! If I had to do it again I would have gone for the Kilo. I'ts smaller at 20" and has a very tight turning radius for use in small pools! I've built a total of 4 Subs all with David's fittings kits and SubDrivers! I'm now going back to the future and working on the Kilo along with David's fittings kit and SubDriver!
