Alfa Plans
    Greg,
    Do you have anything on the Russian Project 1910 Kashalot (NATO designation Uniform) class special operations boat? Click image for larger version
    Originally posted by James Wittaker
    Just sent you the Pr 667A sub plans, please check them.
    Peace
    J
    Got them. Thank you so much! Fresh meat for the folder.
  • James Wittaker
    I already have these. What do you have there, James?
    Peace
    J
  • m.rainbow
    Your book is underway via USPS this morning.
    Imperialist Yankee Dog​
    Great work David. On the 705...
    A big inspiration for me.
    Someone is sending you drawings on 641.
    I also have something and can contribute to the archive.
    Best regards.
    PS: Many thanks for the book.​
    Originally posted by m.rainbow
    When checking the drawing, pay attention to the difference between the early and later versions of pr.641. They have different openings on the light hull.
    Thanks for the tip. I'll be on the lookout.
  • m.rainbow
    My mistake.
  • m.rainbow
    Juliet is the NATO designation for the Project 651 SSG.
    Correct, the label Juliet belongs to pr.651.
    thank you for the warning​
  • James Wittaker
    Hello, Mr Merriman
    For Pr 641 Foxtrot
    , probably the same as yours: (they are from a model magazine I bought)
    Click image for larger version  Name:	Pr 641.jpg Views:	0 Size:	60.6 KB ID:	169754
    I also have the side view diagram of the Pr 641 Foxtrot, I can send them to you if you are interested in...
    Click image for larger version  Name:	Side.jpg Views:	0 Size:	62.2 KB ID:	169755
    I can send you Pr 667A Yankee plans.
    Pr 651~ Juliett class (Nato)
    James
    Hello David
    I am putting together the documents for the 667 A. There will be some drawings, sketches, from various sources. I found some photos from the dock, details of the deck, etc. I believe that you will be able to compile a drawing based on which you will build a perfect model of this submarine. 667A. If there are problems during the construction of the plan, please write in detail. We will put it together together.
    Best regards.
    Miroslav
    PS: Thanks for the copy of the book.​
    This is class 641 Foxtrot. In NATO code "Juliet". No 667 class
    My mistake.
  • m.rainbow
  • m.rainbow
    Hell, I'll send you my copy of the book tomorrow or Monday. I've got all the pertinent stuff from it via other sources.
    Hello David
    Best regards.
    Miroslav
    David. I will prepare everything that is relevant for the construction and send it to you by post.
    I would like to get photos from the book Wayne Frey.Russian submarines,Guardians on the Motherland. That's it. I don't need anything more for now.
    thank you very much​
  • m.rainbow
    Thanks. Hard copies in the mail are preferred. What else can I help you with?
    Yup. I know about the asymmetric height variance between the bow planes. Thanks for the heads-up though.
