Alfa Plans
  • m.rainbow
    • Jun 2010
    • 24
    #46
    ​David. I'll look in the archive /I have about 300 CDs/ and find everything on pr. 667. I will choose what would be most suitable for you for the construction of the drawing. I will send by mail or e-mail. Note - when checking the drawing, I found that the front rudders on the Alfa are not at the same height. From the front, the left rudder is higher and the right lower. .
    Best regards, Miroslav​
      • 14014
      #47
      Thanks. Hard copies in the mail are preferred. What else can I help you with?
      Yup. I know about the asymmetric height variance between the bow planes. Thanks for the heads-up though.
      • James Wittaker
        • Oct 2021
        • 67
        #48
        I got some Pr 667 sub plans, please tell me your email and I'll send them to ya
          • 14014
          #49
          I already have these. What do you have there, James?
          • m.rainbow
            • Jun 2010
            • 24
            #50
            You can send to e-mail : M.Rainbow@seznam.cz
            • m.rainbow
              • Jun 2010
              • 24
              #51
              David. I will prepare everything that is relevant for the construction and send it to you by post.
              I would like to get photos from the book Wayne Frey.Russian submarines,Guardians on the Motherland. That's it. I don't need anything more for now.
              thank you very much​
                • 14014
                #52
                Hell, I'll send you my copy of the book tomorrow or Monday. I've got all the pertinent stuff from it via other sources.
                • m.rainbow
                  • Jun 2010
                  • 24
                  #53
                  Hello David
                  I am putting together the documents for the 667 A. There will be some drawings, sketches, from various sources. I found some photos from the dock, details of the deck, etc. I believe that you will be able to compile a drawing based on which you will build a perfect model of this submarine. 667A. If there are problems during the construction of the plan, please write in detail. We will put it together together.
                  Best regards.
                  Miroslav
                  PS: Thanks for the copy of the book.​
                  • m.rainbow
                    • Jun 2010
                    • 24
                    #54
                    This is class 641 Foxtrot. In NATO code "Juliet". No 667 class
                      • 14014
                      #55
                      My mistake.
                        • 1121
                        #56
                        Juliet is the NATO designation for the Project 651 SSG.
                          • 14014
                          #57
                          Hello David
                          Best regards.
                          Miroslav
                          Your book is underway via USPS this morning.
                          Imperialist Yankee Dog​
                          • James Wittaker
                            • Oct 2021
                            • 67
                            #58
                            Hello, Mr Merriman
                            For Pr 641 Foxtrot
                            , probably the same as yours: (they are from a model magazine I bought)
                            Click image for larger version  Name:	Pr 641.jpg Views:	0 Size:	60.6 KB ID:	169754
                            I also have the side view diagram of the Pr 641 Foxtrot, I can send them to you if you are interested in...
                            Click image for larger version  Name:	Side.jpg Views:	0 Size:	62.2 KB ID:	169755
                            I can send you Pr 667A Yankee plans.
                            Pr 651~ Juliett class (Nato)
                            James
                            • m.rainbow
                              • Jun 2010
                              • 24
                              #59
                              Correct, the label Juliet belongs to pr.651.
                              thank you for the warning​
                              • m.rainbow
                                • Jun 2010
                                • 24
                                #60
                                My mistake.
                                When checking the drawing, pay attention to the difference between the early and later versions of pr.641. They have different openings on the light hull.
