Torpedoes 1:72 scale
    Introducing the D&E Torpedo System
    Download the pdf file here
  • sunworksco
    • 25
    Torpedoes
    My hull is a 1/12th scale USS Holland submarine with a spun aluminum hull.Can I get the torpedo tube in aluminum?
    Can you send me more drawings of how the propel gas tank is plumbed into the torpedo tube ?
    BTW.Brilliant design!
      • 13929
      We don't do guns.
        • 13929
        Recent work integrating the tubes into the GATO kits hull.
          • 13929
          Shipping out to our first customer:
          • Slats
            • 1776
            Mike / David,
            I love the photo of the 6 nested together torpedoes for the Gato,- can imagine similarities with that and looking at the back end of the tubes of a real boat.
            Be sure you stick that in your info flyer Mike, looks cool.
            J
            sigpic
              New basic 1:72 torpedo kit $130
              This basic kit works mechanically, rather than using the electronic controller and solenoid valves of the multiple systems. Using a standard servo, the Breach-block on the Launcher is retracted, releasing the weapon. A 3 position toggle switch on the transmitter is used to fire 2 launchers from one servo. i.e. left = fire #1, center = off, right = fire #2.
              These Mechanical Launchers are not compatible with the Electronic Launchers with Solenoid Valves. The advantage of Electronic Launchers being the flexibility of running gas lines, and the micro size of the valves, rather than the bulkier servos and less flexible push-rods. This would be especially useful in boats like the Revell VII if all torpedo tubes were to be operated.
              The Kit comprises:
              1 x Mechanical Launcher
              3 x Torpedoes
              1 x Standard Servo
              1 x 1/16" Push-rod Seal
              Cost $130.00
              • Scott T
                • May 2009
                • 412
                An idea for building a rack system could be similar to lego blocks that stack up and any number of tubes can be installed up to the maximum of six.
ID:	58308Drawing attached.http://subcommittee.com/SubComm/images/photos/idea.jpg
                If you like it use it.
                Scott
                • petersst
                  • Mar 2011
                  • 3
                  Pictures of Gato parts for mounting the topedo tubes are shown in several messages on this forum.
                  The castings are also talked about on the Caswell site. If I could purchase a set of castings I'd order
                  a set of 6 torpedo kits also.
                  Please help.
