Assembly instructions for SAS SD Skipjack 1/72 model
  • roedj
    • Sep 2008
    • 562
    Sirs,
    I recently purchased the SAS SD 3.5" Skipjack 1/72 model.
    There are no assembly instructions included with it. While I can probably figure out most, if not all of the parts, some instructions would be very helpful. I searched this web site for downloads and the like but could only find zilch.
    Dan
    • 2119
    Ten second search on google-
    http://tinyurl.com/c5uk839
    Plus video
    Not the SAS version I know, but close.
    • roedj
      • Sep 2008
      • 562
      Actually, I have the written instructions for the old two motor SD already. I was hoping for some clues on the installation of the SAS bits. I will go back through all the threads on the development of this system for some help. I have experience with the Merriman WTC so I can probably figure it out but if I was a first time time buyer with no experience I'd probably be scratching my head right now muttering unkind words about the whole process.
      Dan
        • 12253
        Hit me with specific questions and I'll walk you through it, Dan.
        • roedj
          • Sep 2008
          • 562
          Fair enough. When I get stuck, I'll ask.
          But you should probably have a link to downloadable instructions for the total newb as well - just saying.
          Dan
            • 12253
            What's this? Doctor Meacham can't assemble a simple Interoceter without the Assembly Manual???....
            You disappoint!
            Exeter
            • roedj
              • Sep 2008
              • 562
              All right, clown, maybe I'll post some pictures of you in those lovely, and I do mean lovely, pink shorts. We can call the whole thing, "This island Girth" Dan
                • 12253
                No! ... for God's sake .... NOOOOO!!!!
                I'll behave.
                • roedj
                  • Sep 2008
                  • 562
                  supplied servos in the electronics kit for the 3.5" SD
                  This is the micro servo supplied with the 3.5" SD electronics kit...Click image for larger version
Name:	servo supplied with 3-5 inch electronics kit 002.jpg
                  This is the mounting system (I think) on the 3.5" SD...Click image for larger version
Name:	servo supplied with 3-5 inch electronics kit 001.jpg
                  Either the wrong servo was supplied or I'm missing something.
                  I have some of these older bigger style servos (on the left) in my supplies...Click image for larger version
Name:	servo supplied with 3-5 inch electronics kit 003.jpg
                  The older bigger servo seems to fit nicely in the mounting brackets...Click image for larger version
Name:	servo supplied with 3-5 inch electronics kit 004.jpg
                  Is this what you had in mind?
                  Dan
                  • roedj
                    • Sep 2008
                    • 562
                    snorkel theory
                    When the snorkel is closed - sub submerged - how does the snorkel head appear?
                    Does it look like this...Click image for larger version
Name:	snorkel head 001.jpg
ID:	76844 and then closed like this...Click image for larger version
Name:	snorkel head 002.jpg
                    does it look like this...Click image for larger version
Name:	snorkel head 003.jpg
ID:	76846 and closed like this...Click image for larger version
Name:	snorkel head 004.jpg
                    I could make a case for either one but you probably had one of them in mind when designing this system.
                    Or, am I totally wrong on the whole concept?
                    Dan
                      • 1290
                      Dan,
                      The first two pictures show how it's done right, this way the brass inlet tube will be sealed by the rubber, which is glued on the float, never ever use the method shown on the last two pictures, unless you like to swim and dive for your sub.
                        • 12253
                        Originally posted by MFR1964
                        Dan,
                        I think Dan is having a bit of fun with us, Manfred. Oh, these mortals are such a handful, don't you think?
                          • 1290
                          Hmmmmmmmmm, i can't stand it if mortals have fun.
                          Let's see........., ahhh, i''ll switch on the lightning generator, and will give him a few bursts, let's see if he likes to be carbonated, that will teach him to use my precious time.
                          Manfred
                          • roedj
                            • Sep 2008
                            • 562
                            Dearest Olympians,
                            Thank you both for replying to my little query. I suspected that the right way was the first two pix but with "He Who Must Not Be Blamed" it's always best to ask.
                            So I take it that I should use my older servos as well and that supplying me with smaller servos that don't fit the mounting brackets (see post #9) was just a test to see if I was paying attention.
                            Dan (serf 4th class)
                              • 1290
                              Strange..........., i smell burned mortal
