Gas Ballast Fill Adapter
  • biggsgolf
    • Jan 2020
    • 1035
    Are there any tricks to using this adapter to fill the tank? What are the steps? I am using a 250 Series SubDriver. How can I easily test to know its full?
  • biggsgolf
    • Jan 2020
    • 1035
    Should the vent be in neutral when filling? How long should it take while can arm is depressed? Do I do short multiple depressions?
      • 2043
      Clamp valve, invert can. Keep your finger on your ballast blow control. Depress the filler valve and keep it depressed. "Burp" the ballast on your transmitter. Two seconds on, two off. Wait until liquid sprays from the valve in the cylinder and not just air. Let up on the filler handle. Unclamp.
      Done!
      • biggsgolf
        • Jan 2020
        • 1035
        Done!
        Thanks Bob!!
