If you are referring to the HMS Holland!
The Holland has been in the water! One time testing the WTC and setting up the boat trim!
10-09-2022, 02:04 AM
Today I put the Holland 1 together and did a quick run in the pool just to see how everything was working and checking for any leaks in the WTC!
It all went very well. I am going to add an extension onto the bottom rudder in order to give it more surface area so I can improve on the turning radius. I may need to add two pieces of foam in the upper hull just to stabilize the boat a little more.
Check out the youtube above for more in the water!! And by-the-way, I do not recall seeing ANY of your boats in the water!!
