End cap seal failures
  • scubaed1911
    • Jul 2019
    • 45
    What's the best way to install/seal which runs thru end caps to prevent leakage? Two of my seals thru endacp (they appear to be a synthetic rubber material) leak, and the seal from servo to rudder control separated from my endcap completely. Thanks!
    • 13575
    Are these the 1/4" diameter resin seal bodies that accept 1/16" pushrods? If so I have a few here you can have.
      • 3667
      In David's green photo above the first item is using a cup seal (great for prop shaft) and the other two are o-rings cast in resin. Those are typically for pushrods, but some also use for prop shafts.
      Tom
      • scubaed1911
        • Jul 2019
        • 45
        Thanks David and Tom! I'm interested if you're parting with those! And yes, the 1/4" seal bodies to accept 1/16" rod.
        Ed Frank
        864 361 7510
          • Jan 2020
          • 1004
          As David shows here, easy to replace, I find inserting a 1/16” rod helps inserting into encap
          • scubaed1911
            • Jul 2019
            • 45
            Thanks! Are these a friction-fit or are the sealed? If sealed, what with?
            Is there a commercial source for these? Haven't seen offered at the DryDocks.
            Thanks!
              • Jan 2020
              • 1004
              I use RTV Silicone Gasket Adhesive Permatex 81724
              The actual seals are only by David or Bob. Bob posted a video on making your own:
                • 13575
                Thanks!
                The seal bodies within the motor-bulkhead? If so, they are secured with RTV adhesive.
ID:	150024Click image for larger version
ID:	150025Click image for larger version
ID:	150026Click image for larger version
                  • Jan 2020
                  • 1004
                  Email Bob @Drydocks and he may have some. He generally replies the following morning
                    • Jan 2020
                    • 1004
                      • 1966
                      Was just about to post the link up! Thanks for saving me the trouble!
                      • scubaed1911
                        • Jul 2019
                        • 45
                        Bob, the seal that popped out from aft bulkhead had no indications of sealant on it!
                        Anyway, I may have a few seals coming from David, and will seal appropriately. Thanks
