LOS ANGELES class Sub on Scale 1/81 (I thnik?)
  • profesorul
    • Mar 2010
    • 63
    Post Nr:15
    And that's all for know ,
    MARIUS
    • profesorul
      • Mar 2010
      • 63
      HELLO ,
      I don't know what is happening to my posts !?.
      Where are the OTHER 14 posts with pictures ?!?!?! .
      Way is taking so much to be published ?!.
      MARIUS
      P.S. to day March / 23 / 2015 , 11.50 Est European Time . GMT +2 .
      • profesorul
        • Mar 2010
        • 63
        These Pictures :
        http://postimg.org/my.php?gallery=5bo8sp2o
        MARIUS
        P.S = if I put only the link , nobody is going to look at pictures becouse are a lots ! .
          • 13979
          Originally posted by profesorul
          These Pictures :
          MARIUS
          Those are my pictures, Marius
          • profesorul
            • Mar 2010
            • 63
            Not much work these day because I'm stuck with a problem : >:-o
            - the distance between the steering rudders axle and depth rudders axle is very small and do not know how to manufacture coupling rudders ....
            - because of that I can't get a left / right rudders movement necessary for the turn submarine and no movement up / down for dive planes ,
            The distance I took it form the drawing and scale distances table , but doesn't seems to be right . >>:-(
            May be You can give me some advices .
            MARIUS
            • Peter W
              • May 2011
              • 511
              Marius pictures would help, but some where you will find info on Mr M's D&E 1/96 Skipjack kit/build. I would imagine that he had these problems and he definitely will have overcome them, a 1/96 skipjack is a tiny beast compared to a 1/81 LA.
              Peter
              • profesorul
                • Mar 2010
                • 63
                You are Absolutely Right PETER .
                It was guest a small problem witch I experienced , among many other wheel follow .
                MARIUS
                • Peter W
                  • May 2011
                  • 511
                  Marius
                  Post your problems here, there is certainly the quality of modeler here to help amongst the other chaps, they have certainly helped me , but obviously pictures will help.
                  Peter
                    • 13979
                    Peter
                    BEHOLD!! (crack of thunder)
Name:	DSCF3384 - Copy.jpg
ID:	98080 Click image for larger version
ID:	98081 Click image for larger version
ID:	98082 Click image for larger version
ID:	98083 Click image for larger version
ID:	98084 Click image for larger version
ID:	98085 Click image for larger version
ID:	98086 Click image for larger version
ID:	98087 Click image for larger version
ID:	98088 Click image for larger version
ID:	98089 Click image for larger version
ID:	98090 Click image for larger version
ID:	98091 Click image for larger version
ID:	98092 Click image for larger version
ID:	98093 Click image for larger version
ID:	98094 Click image for larger version
ID:	98095 Click image for larger version
ID:	98096 Click image for larger version
                      • 13979
                      ... and this is how you make 'em:
ID:	98098 Click image for larger version
ID:	98099 Click image for larger version
ID:	98100 Click image for larger version
ID:	98101 Click image for larger version
                      • profesorul
                        • Mar 2010
                        • 63
                        Sorry , I forget the pictures :
                        MARIUS
                        P.S - now I have to save those pictures to a separate folder and print them on a large scale . MANY THANLS .
                          • 13979
                          MARIUS
                          Install the stern plane operating shafts the way I showed and you can get away with the tight bushings.
                          • profesorul
                            • Mar 2010
                            • 63
                            I can't enlarge them !!! .
                            Do You have a external Link where can see them BIG ?.
                            I'm wearing glasses !!!.
                            THANK YOU ,
                            MARIUS
                            • profesorul
                              • Mar 2010
                              • 63
                              HI there ,
                              These waht came up for Dive Planes :
                              MARIUS
                              • profesorul
                                • Mar 2010
                                • 63
                                #30
                                Some small update for it :
                                At the end is going to be painted only with primer and the some grese
                                MARIUS
