Japanese Class A 1/16
    • 1304
    Thanks Guys,
    The no tool needed part has his roots from the XXIII, tools like water in some mysterious ways, they allways dissapear.
    This time i wanted to use the SD as standard as possible, yes there will be some mods, but not that much as with the type XXIII, i will keep everything KISS as possible (except shooting torps).
      • 1304
      Now the magnetic thing is done, i could start with some other things, first i attacked the conical shapy thing, it was obvius i needed more room to play with the connection for my rudders and divingplanes,
      First i made a base-plate at the end, secured it with conical screws.
      Removed the base-plate and took the dremel to hollow it out, by doing this i can easely access the back-part for installing the rudder/diveplane thingys.
      Inserted the gearbox inside with the aid of some brackets, it can be removed by loosening the screws, used no bearing at the end because the gearboxshafts are supported by the gearbox itself.
      This is the beginning of getting a connectionshaft between my gearbox and the SubDriver, those things present will be the supports for the shaft, connecting both sides of the shaft will be done in the same way as with the type XXIII.
      Have to make some receivers on the lathe for that, the receivers will be placed on the shaft, prefenting it to fall out of the rearpiece hull.
        • 1304
        It has been busy inside the Cave, placed the connectionshaft from the SD to the gearbox, glued down the stabilising fins and did some work on the tower.
        Click image for larger version  Name:	P2110017.JPG Views:	1 Size:	16.3 KB ID:	125196
        Click image for larger version  Name:	P2110018.JPG Views:	1 Size:	16.3 KB ID:	125197
        First some showpictures, she is rigged up in full dressing.
        Click image for larger version  Name:	P2110020.JPG Views:	1 Size:	15.8 KB ID:	125198
        While gueing down the fins i could do some work on the tower, managed to get the hatch placed and drilled some ventholes.
        Click image for larger version  Name:	P2110022.JPG Views:	1 Size:	12.7 KB ID:	125199
        By using some tubes i could connect the shaft from the gearbox to the SD, poured in some glue on the brackets and let her dry for 24 hrs.
        Click image for larger version  Name:	P2110023.JPG Views:	1 Size:	15.8 KB ID:	125200
        Here you can see those brackets complete with their bairings for guiding the shaft, still have to make the special connectors on the lathe.
        Once the fins where glued i could add the propguard, unfortunally i have to redo the propguard it is fitting too tight and deforming the shape, you can take the part off as one unit.
        Click image for larger version  Name:	P2110025.JPG Views:	1 Size:	16.4 KB ID:	125202
        The bow netcutter is placed with a M3 screw, by turning the reinforcment-rod you can take it loose.
        For now i have to solve the problem with my cables on top of the boat, in this configuration it's not possible to take off the tower when needed, and the connection to the bowpart is not easy to take off without loosing parts.
          • 12321
          Hey, Manfred
          I've been using those little (but powerful) magnets to hold the jumpers to the sail. Easy make/break arrangement.
            • 1304
            Ah, so those magnets are strong enough to hold the wires, i've got me some work to do tomorrow, thanks for the tip David.
              • 1304
              This tensionwrench was my issue, due to the present tensionwheel above on the tower you can't remove the tower easely, David mentioned the use of magnets, so i altered the construction.
              Step one was placing a little magnet at the base of the tower, next step was placing a tin plate at the bottom of the tensionwrench, now you can remove all stuff at will.
              This was my first solution for the bowpart, a simple hook to take away the cable, but i was not satified, it had to be more scale yet simple.
              After some work i ended up with this, it looks like the cable connector at the tower, but it has a twist.
              You can swing open the lockingbar to release the cable, it uses the tension of my cable to stay locked, simple and no tools needed.
              For now i have to rebuild the propguard, i'll strip down the old one from it's bars, they wil be re-used at the new one, allready did some homework for making the rudders and divingplanes, they are now laminated and drying, can wait to get the full picture.
                • 1304
                Despite i'm posting nothing, there is still activity inside the Cave,
                Last spring i met this wonderfull guy in the real, had to travel to the Island of Korfu in Greece, i knew Giannis was living there, so i contacted him by mail to try to meet up, as the picture shows we did at his cave, that man is a wizard, seen lots of stuff and we had a good chatt about everything.
                Dugged up the molds from the V80 and started prepping them for building hull number three, as you guys know David had lost the hullparts during the flood a few years ago, and since i had the mold i promised David to make a replacement.
                After prepping het mold i added the gelcoat for starting with the first layers.
                The rest is pretty straight forward, adding layer after layer, David had the request to make it a bit thicker, i went for 1 mm wall-thickness.
                This is alllways the exciting part, pulling the hulls from the mold, you often wonder if the prepwork went well, i must say, the result was better as the first pull for David.
                After cleaning up the flash it is time for sanding inside the mold, this way you know all edges will be equal, so both hull parts fitt together without much of a seam.
                After sanding i cleaned up both hull-parts and the mold, the mold is still in good shape, i guess she will survive a few more pulls.
                Still have to do some minor things, but a dry-fitt was possible, it's still funny to see two of the same hulls together.
                Did this in small steps the last few months, for now the Cave is closed due to the high tempartures, it's like living inside a oven, she has to be boxed up for sending it to David.
                  • 12321
                  Much appreciated, pal.
                  First thing I'll do is bond the two halves together, then cut the top of the hull away from the lower at the waterline. Then work out the indexing of the two halves, and set them aside while other work is attended to. Thank you, Manfred!
                    • 1304
                    Glad i could help you out with some new hull parts, can you give me your postadress by PM, otherwise it will take much too long to get the stuff inside your cave
                    Manfred
                      • 1304
                      Picked up the pace at the cave, David has been stuffed with the V80, so i have my hands free, i had to make a new protector ring, cutted some copper strips and started fiddling.
                      Clamped down al rods before i could start soldering.
                      This was the easy part, it revealed to me i had a issue with the hull, you can see the gap between the prop and the hull, have to make a ring to get me a nice transition, this item will be noted down on the list.
                      The final coupler on the shaft to my gearbox, pretty much the same style as used on the type XXIII, did this on both ends of this hull piece, so i can still take it off.
                        • 12321
                        Getting closer each day, Manfred. This is going to be another stunner when you're done with it, my friend.
                          • 1304
                          Take one nibble at the time and she will see water in the future, in the past i allready made some preparations for making the rudders and divingplanes,
                          First i prepped some laminated stuff with the aid of a roll of flat lead.
                          Took the dremel and cutted the plates rough into their shape, i inserted a copper tube during the lamination process, those black specs are mini grubscrews M2, those will secure the stuff onto the copper rods.
                          Next step was, making the final dimensions for both the rudder and divingplanes, took measurements for the allready build rearpart to get it right.
                          All parts testfitted at their place, next step will be, giving the parts some profile and start thinking at how to couple the steeringrods, i have some idea's but first the profiling.
                            • 12321
                            Get'n there, Manfred. This is going to be a beaut!
                              • 1304
                              Shaped the divingplanes and rudders, also attended one other item, it seems the hull is a bit off at the end, it should match the diameter of the prop, but it doesn't, solution was, making a piece to make up the space.
                              Laminated some circuitboard and did some work on the lathe, resulting in this.
                              Click image for larger version  Name:	IMG_1552.JPG Views:	1 Size:	70.6 KB ID:	128265
                              A composition of all parts, yet again i raped David's designed prop for my own purpose.
                              Click image for larger version  Name:	IMG_1553.JPG Views:	1 Size:	64.3 KB ID:	128266
                              First step is placing the transition ring, it is kept at it's place with one conical 2 mm screw.
                              Click image for larger version  Name:	IMG_1554.JPG Views:	1 Size:	73.7 KB ID:	128267
                              Click image for larger version  Name:	IMG_1555.JPG Views:	1 Size:	73.7 KB ID:	128268
                              By moving the prop backwards i created a problem with the endcap, it could not be secured anymore with the present grubscrew, carefully i drilled some holes through the rear prop and tapped M2 threads into the endcap, this had to be done right in one attemp, i only have one prop!!
                              By using conical screws they are flush and won't be a problem with turning of the prop.
                              Click image for larger version  Name:	IMG_1556.JPG Views:	1 Size:	76.5 KB ID:	128269
                              Two parts together, not a trace to see how the endcap is secured to the rearprop, Phew!!!
                              Click image for larger version  Name:	IMG_1557.JPG Views:	1 Size:	67.8 KB ID:	128270
                              The rest is pretty straight forward, first prop is secured by a grubscrew, second prop the same way, this contraption gives a nice transition from the hull to the prop, once painted it will be not that visible.
                              Now i'm playing around with another issue, since the rearpart becomes heavy it gives too much strain on the magnets, giving me a minute gap between the hull parts, it's not a big issue, but i want to have this solved before i start annoying myself on this.
                              • bassplayer1
                                • Mar 2010
                                • 244
                                Manfred, I've got no words!!! You are amazing my friend. By the way, thanks for the photo !!!
