1/96 Scale Shipyard Alpha
    Pretty darn close. Looks like the body of the sensor below the radome narrows in the centre and fears at the top and bottom. The side plate antennas are sitting just outside the base of the dome and the curved mesh antenna's horn is mounted very low on the body of the sensor. That forward mast is a killer as well. Until I saw the recent Polish photograph I thought that it looked elongated but its actually more disc like. And the biggest gotcha of all is the (navigator's)periscope that I thought was a satellite antenna! Live and learn.
      Geeeezzzeee.... I hate auto correct!!! Perhaps the body could flare at the top and bottom, instead of fearing!!!
        • 3757
        #48
        Wonderful research guys!
        • bwi 971
          • Jan 2015
          • 940
          #49
          Can't agree more Tom......that are some incredable pictures Scott.
          Grtz,
          Bart
          "Samuel Smiles"
            Found this early this morning:Click image for larger version
ID:	97988Click image for larger version
ID:	97989Click image for larger version
              Todays little achievement. Old and new. Click image for larger version
              • profesorul
                • Mar 2010
                • 63
                #52
                Originally posted by HardRock
                Todays little achievement. Old and new. [ATTACH=CONFIG]30751[/ATTACH]
                HI Scott ,
                Excelent job SIR .
                Those Masts are made on lathe ? / what material did You used ? .....or You cast them ?.
                MARIUS
                P.S . that light from antenna send to PETER cames from an SMD LED ?. ....or what ?.
                If Yes , how the H*** did You do it ?! .
                THANK YOU
                  Hi Marius,
                  You can purchase .8mm LEDs from these guys
                  12volt LED lights for modeling project, top-quality, affordable. Elevate your models with radiant illumination. Ideal for various DC-powered hobby applications.
                  I am very lucky to have a small lathe and it does very well with most things. There is a grave yard of not quite perfect masts, however.
                    Originally posted by profesorul
                    HI Scott ,
                    Excelent job SIR .
                    MARIUS
                    THANK YOU
                    The shafts are stainless steel. The other bits are sandwiched polyurethane, turned down on a lathe. The light that Peter has fitted to his Akula is a .8mm LED sitting on a 1.5 mm aluminium shaft with a clear plastic top which I drilled out and turned down to fit the shaft. It needs a black top and base ring at present.
                    • profesorul
                      • Mar 2010
                      • 63
                      #55
                      THANK YOU so Much SCOTT for the explanations .
                      MARIUS
                        This is the final iteration of the dreaded MRP-23. Its not perfect but its the best that I can do.
ID:	98033Click image for larger version
                        And looking at the blown up photographs I have just realised that I put the antenna dish on backwards! Bugger.
                          • 3757
                          #57
                          That is pretty stinking awesome!
                          • Peter W
                            • May 2011
                            • 511
                            #58
                            Looks excellent ! but .....you need a pic of it in the sub!
                            Peter
                              Still working on the other antennas!!
                              • profesorul
                                • Mar 2010
                                • 63
                                #60
                                HA ,
                                If these is not awesome , than what is it ?!?!?! .
                                I think it's better than you "GURU" of scale models are far from each other, on different continents, for otherwise the world would have been depleted of talent ,
                                So you can also share your experience to those around you and , in that way many people have won .
                                I think you are often too demanding with yourself , trying to make something perfect ,
                                In that way You waste your energy / time , energy useful to create other projects as great ,
                                Just a thought aloud .. .. not paid any attention ,
                                We as Apprentice are glad that can learn from You .
                                MARIUS
