32nd Parallel's Type XXIII
  • cliffhanger67
    • Oct 2013
    • 83
    I found the instructions on how to do it.
    [ATTACH=CONFIG]20019[/ATTACH]
    Not sure I understand this instruction. So what should be the input to disable or command for fail safe desired. The example is the one to use? Sorry, not very savy at this. Thanks.
      • 3768
      Apparently you cannot turn of the signal. It is built into the RX. All that can be done is set it. The other caution is there is not a delay in the signal lost, it is instantaneous. It has been 5 years since playing with this, but if I remember correctly, you attach a battery to the RX (aa pack or NiMh pack or regulated power or your power while in the sub) with the TX off (red LED will flash on the RX, the instructions say 16 seconds. I do not remember) . Then move your TX sticks and all your controls on the TX to the positions you want when signal is lost, hold them in that position then without letting go, turn on TX. Once the two communicate, it is set.
