Need Help 1/350 Dragon Typhoon R.C Conversion
  • george
    • Dec 2010
    • 731
    Hello
    Like the title says, I have a 1/350 Dragon Typhoon that I would like to convert to a R.C Static diving submarine with a WTC and air bag system. I need advice, what size WTC to use, dia., length etc. I have practice with small electronics, servos,motors. I would need a SMALL 4 ch 75mhz FM receiver, failsafe etc.
    Basically any tips you can offer as well as pictures, plans etc. would be Greatly Appreciated. I know this is nuts, I`ve heard even more comments about this plan I can`t repeat here also.
    Please any info you can share would be helpful. I`ve seen the work done so far with the lower hull sectioned off to do this but I like the WTC system instead. I don`t think there is enough room though for a snort so the WTC supplies the air for the air bag.
    Thanks for your help in advance.
    George
    This one has snort http://www.rcgroups.com/forums/showt...hlight=typhoon
