Hi John,
Looks very good, man! I'm particularly pleased at the amount of ballast tank required (or lack thereof). That means success in my book! As for the shaft issue that you have addressed I actually designed the solid stainless shaft to end just forward of the bearing bulkhead leaving enough metal for a universal socket to attach to. The length that spans between this socket and the Sub driver drive socket is to be taken up by the 'cut-to-size' hollow 7/32" tube. The supplied nylon dog bone is cut in half, inserted on both ends of the shaft, drilled through and pinned in place with wire. This gives the Wolf and easy to remove and re-install intermediate drive shaft. To bolster the hollow tube further if required, a solid 3/16 rod can be cut to size and placed in between the dog bone ends.
Joel
Joel
