Rubis class SNA Perle (S606)
    • 950
    RUBIS CLASS Build Thread
    SNA PERLE (S 606)
    Model in 1/64 scale.
    Model Length 45.25 inches. (1149.35 mm.)
    Beam 4.68 inches. (118.8 mm.)
    Click image for larger version  Name:	S-604-FS-Emeraude-05.jpg Views:	0 Size:	56.2 KB ID:	195767
    Sous Marin Emeraude (S 604)
    Click image for larger version  Name:	rubis amph.jpg Views:	0 Size:	73.4 KB ID:	195768
    Click image for larger version  Name:	randy stern.jpg Views:	0 Size:	49.0 KB ID:	195769
    Randy Sanders Stern Design
    Click image for larger version  Name:	stern printed.jpg Views:	0 Size:	51.9 KB ID:	195770
    Click image for larger version  Name:	stern measure.jpg Views:	0 Size:	46.7 KB ID:	195771
    Click image for larger version  Name:	be.jpg Views:	0 Size:	51.8 KB ID:	195772
    Keith Bender RUBIS Prop
    Click image for larger version  Name:	rubis prop real.jpg Views:	0 Size:	53.6 KB ID:	195773
    Click image for larger version  Name:	rubis sail.jpg Views:	0 Size:	44.7 KB ID:	195774
    Click image for larger version  Name:	s 602.jpg Views:	0 Size:	47.3 KB ID:	195775
    • 950
    variance in rubis tops rudders
Name:	rubis class top rudder profiles.jpg
    Click image for larger version  Name:	rubis rudders photo.jpg Views:	100 Size:	43.2 KB ID:	195793
    • Akula54
      • 53
      If you are still interested, i can purchase some drawings with right design/form of the Amethyste class.
      Click image for larger version  Name:	schnorch.jpg Views:	0 Size:	85.0 KB ID:	195809
      Click image for larger version  Name:	Capture d’écran 2024-02-20 191114.jpg Views:	0 Size:	48.0 KB ID:	195811
      Click image for larger version  Name:	massif amethyste.jpg Views:	0 Size:	59.7 KB ID:	195812
        • 950
        Thank you for the drawing. The sail is already completed (printed) and happy with accuracy, unless you spotted something inaccurate, I missed. If so, can you share, please.
        My drawing is close but not accurate enough to be definitive to me. Can you post here from your drawing the stern and its rudder and horizontal plane shapes please?
        Your drawing is a big help on the masts. Merci.
          • 950
          Printing of all the Rubis parts should be completed by Monday June 22. 2026. Will be placed in a box separate from Suffren parts work till Suffren is done. I am having extra Suffren dive module supports printed too & will have the outer circumference using my bench disk sander cut down to fit the smaller Rubis hull. I will use U stern plane connectors for the Rubis for the stern planes and rudders. I am using parts refurnished from old subs model no longer in service. (from my old Skip Asay Albacore). A few parts
          remaining printing now to be done by Monday
          .Click image for larger version  Name:	rubis parts.jpg Views:	0 Size:	47.2 KB ID:	195884
            • 950
            All parts printed and set aside , in wings as Suffren finishes. Some new masts being made. Really a generational leap in technology between the Rubis 1980s and Suffrens 2025-2030.
Name:	Rubis parts box.jpg
              • 950
              Doing some preliminary changes to the Rubis class so rudders match the Amythyste and Perle top rudders.
              Cutting new rudder holes, so rudder and stern plane control rods off set for clearance internally. Aligning with brass tubing as a fixture to keep everything aligned and new brass tubing ridder holes lined up and CA glued & puttied. So straight to the new pivot axis's points.
              Upper profile changed to match Perle's upper rudder, this rudder is taller and narrower chord. Rudder silhouette is rounder on top also Use styrene solid stock to block out and shape.
              Some touch ups to the sail lower rear, building up with styrene and Bondo putty.
              Click image for larger version  Name:	Rudder cut 1.jpg Views:	0 Size:	38.0 KB ID:	196061
              Click image for larger version  Name:	rudder cut 2.jpg Views:	0 Size:	94.1 KB ID:	196062
              Click image for larger version  Name:	sail rubis putty.jpg Views:	0 Size:	38.6 KB ID:	196063
              • Akula54
                • 53
                Please, take a look to your PM I've sent to you.
                Should help you.
                regards
                  • 950
                  Should help you.
                  regards
                  as you hav
                  Making corrections from stl file. The Randy Sanders STL file is correct for the first 4 boats in class. But last two - Perle and Amythiste rudders are different. Chose Perle because me and Keith Bender agreed Perle easier to spell...lol. Thanks, I got this.
                  Below shows your build with different rudder shape which I an changing to approx.
Name:	akulas Rubis rudder.jpg
                  • Akula54
                    • 53
                    As I mentioned in a private message, I have drawings that can help you create a model with more accurate shapes.
                    The printed model made by Minialand is right in form, but he took liberties with the technical solutions that I do not agree with. Too bad.
Name:	Capture d'écran 2026-07-02 233458.png
ID:	196070 Click image for larger version
Name:	lower rudder.png
                      • 950
                      Merci beaucoup. Cela tombe à point nommé.
                      (Thank you very much. This is timely.)
                        • 950
                        Using the drawings above. Aluminum tubing leqding edges - simple and works. Vertical rudder holes also shifted back 5 mm.
                        Click image for larger version  Name:	amy 1.jpg Views:	0 Size:	41.9 KB ID:	196128
                        Click image for larger version  Name:	amy 2.jpg Views:	0 Size:	42.1 KB ID:	196129
                        • DrSchmidt
                          • Apr 2014
                          • 1393
                          Why don't you adjust the CAD model and print it again?
                            • 950
                            I don't know how to CAD yet and don't have the patience and 2 years to learn it. The person that designed it was gracious enough to design for me and paid him But he's too busy to make the changes.
                            I asked him to make a few changes but he didnt.
                            He's nice but I don't want to push my luck asking him to make more adjusts.
                            There are other things I need to change too, the casing main hatches are curved to the hull and not flat circular landing pads also. I did a lot of changes to correct the Dolphin Israeli sub model earlier too with same hatches. Its a 35 mm diameter metal washer and I grind away a depression in the hull deck so its flush. And add a scribed in hatch in center that matches the Suffrens and putty and sand. Because I use an inexpensive metal washer bushing, the metal edges holds its shape effectively when sanding .
                            Besides the hollow tubing permits a conduit for wiring for a rudder light on top too.
                            It is far easier to make corrections myself than negotiate or wait more. .
                            Also, after printing parts my mother board blew in my Any cubic printer, and I cant get parts to replace even this soon after purchasing. The 3dprinters evolve so quickly and its Bull**** parts are not available to repair worldwide after just 24 months.
                            So, I like 3 d printers when they work, they are miracles. But to learn how to use, the hassles operating and them blowing up. No wonder in You tube 'educational videos' (jokes) the narrator says this is my 7th new printer. WTF?
                            So digital or analog, and good ole using my hands and eyeballs, I must press on. These printers are still too easy with just normal use to break their dicks.
                            Printers are like kids like the line from 'True Lies'. "Kids. 10 seconds of joy, 30 years of misery."
                              • 950
                              Stern filets added. Will reshape horizontal plane fillet leading edge too soon. Fun stuff.
                              . Click image for larger version
Name:	stern sanding 1.jpg
Name:	stern sanding 2.jpg
