Building the little Kilo submarine
    • 1633
    #61
    Excellent that all things went well Tom, i'll keep the resin on hold just in case
      • 3637
      #62
      Manfred,
      where did you tap power for the LPB?
        • 1633
        #63
        Romel, i tapped the power from the main bus, in this chase 6V, that LPB i use is rated at 6V, so no resistor needed.
          • 3637
          #64
          Thanks. By the way, hows the weather there now?
            • 1633
            #65
            It's still hot, today around 35 degrees Celsius, did some testing with the V60 and now i have to reglue some parts, they came loose due to the heat, next time i need some shade when on the shore
