1:96 USS Dolphin
    You can easily encase all the linkages within that stern:
    No photos.
  • RCENGR
    started a topic 1:96 USS Dolphin
    1:96 USS Dolphin
    This thread is to document the build of a 1:96 scale USS Dolphin that is being built in collaboration with SVilling. I'm the chief engineer and master mechanic, while Steve is owner, financier, program manager and sub expert. We started this project once we decided that we would attend the RC Subfest Redux at the end of April. Steve's requirements were for a 1:96 model (I did try and talk him into 1:72), RCABS, and an AD2.He wanted a z cut hull with the cut line at the waterline instead of in the middle. He gave me a 1.75" OD x 1.625" ID x 12" tube to use as the WTC.
    I fired up the CAD program and had a hull done in a couple of evenings, due to the simple nature of the design. The first design decision was how to access the linkages in the tail. I played with a hatch, but ultimately ended up with a tailcone that bolted on with 4 2-56 bolts.
    Next was figuring out how to do the linkages. I decided early on that the pitch planes would be done externally. That left the rudder yoke to go inside the hull, which was 0.75" diameter at that point. I started by soldering 1/16" wheel collars to some 1/4" square tubing. That worked, but it was a little wonky, so I drew up a 3D printed part that used 1/16" wheel collars.
    I included supports for the WTC in the hull.
    The Dolphin in its carrying case
