GATO! (It has begun)
  • crazygary
    Hiya, Matt!!
    Can you see what's preventing the prop shaft from going in any further??
    You may be able to just shorten the motor end of the shaft a bit so the prop hub
    sits right up against the strut tube.
    The way it is, it might create a little unwanted cavitation!? Not sure how critical that is with a model sub,
    but probably not a good thing with a 1:1!!
    CG
  • matthewnimmo
    Here are some shots of what im talking about. Im probably ok but figured id ask Click image for larger version
  • matthewnimmo
    Sigh... So I got them on but one side is not as far on as the other and I really don't want to try to get those suckers off with that super glue. Will that mess with the performance any?
    Flat face aft, curved face forward. Duh!
    R.H turning to starboard, L.H turning on the port side.
    Sounds like you're almost there, Matt.
  • matthewnimmo
    Quick question which side faces aft on the props again?
    (insert evil, Bender like, laugh)
    Originally posted by matthewnimmo
    Please do answer it for me Tom:)
    thanks!
    Mine is about 40% forward and 60% reverse (to get me out of trouble- like walls of a pool!) The changes are not just for trim, but for running. Even at 40% (and I have dialed it back from 50% originally set) because this sub has so much power with those two props and WAAAY to fast - read get into trouble quickly. While trimming out the sub in your tub or favorite watering hole, try running it (while holding it with your hand) at 100% you will see what we mean.
    ... start with 30% -- 30%. You may want to keep it there after flirting with more throttle. I did.
    The two 380 motors, geared 3:1 in the stock GATO SD provide way, way too much torque for that boat (better too much than too little!).
  • matthewnimmo
    Breaking bits and pieces is why I do not put them on until I get the sub running - it is inevitable. My Gato taught me that too.
    Ohhh let me answer about the throttle, because that beast flies!
    thanks!
  • matthewnimmo
    Went with toms suggestion this time. Little more expensive but they have about twice the pull strength.
    every freaking time i touch my sub now i break something small on it. I mean its been every damn night! <\rant>
    Question for you David (i guess for anyone that knows really), earlier you mention trimming back my throttle to 30% both directions. Is that just for trimming out the sub or is that how i should always have my throttle at?
    thanks everyone
  • crazygary
    Hiya, Matt!!
    Check out: gaussboys.com
    CG
    There are many places you can get them, I use http://www.rare-earth-magnets.com/p-10-nsn0572.aspx
    The inside diameter I use is .125" with a little lathe, Dremel, or drill you can shave down a brass tube to fit (and you will need to)
  • matthewnimmo
    Tom/david
    quick question about barrel magnets. Where can i get some? I saw them used on Tom's gato build and im curious
    thanks guys
