Project type XXI scale 1/96
  • Davjacva
    Originally posted by MFR1964
    Romel,
    There is not that much room to get a gearbox inside, so it will be logical to follow what David did, still working on other things before a can make a fit with the SD.
    Question for David, if i decide to run them in the wet, are there certain things to do after a wet run, i would think lubricate them with WD 40 and make a dryrun to get the WD 40 all over.
    Manfred, about 20 years ago I thought it was bonkers, but we got some RC car and truck people involved with tanks, and they always break-in their motors individually inside a glass on water. The main purpose is to wear-in the brushes, which provides a more stable voltage output, and it cuts down on arcing/ sparking which effects radio reception. Dave told me after running his that the motors run much better and this stands to reason.
    Romel,
    No, i want to do that the old fashion way with some hidden screws underneath the deck, not really a fan of using just magnets to keep the conningtower at his place, a XXI without the conningtower after patrol is not what i'm looking for.
    I thought the magnetic connector was for attaching the sail to the hull...
    Thanks for the tips guys, first i will follow the route David went, if needed i can try plan B, first have to get at the stage of rebuilding the SD for my needs, don't know if there will be enough space left for realising plan B
    Finished up the magnetic coupling of the rearpart and done some work on the conningtower,
    Click image for larger version  Name:	20241109_131532.jpg Views:	0 Size:	51.8 KB ID:	185014
    It should work like this, using the pins as a guide and the magnets to keep it at its place
    Click image for larger version  Name:	20241109_132213.jpg Views:	0 Size:	53.8 KB ID:	185015
    Removed the copper layer at the backside in preparations for glueing
    Click image for larger version  Name:	20241115_144122.jpg Views:	0 Size:	53.0 KB ID:	185016
    First part being glued to the rearpart.
    Click image for larger version  Name:	20241115_144726.jpg Views:	0 Size:	53.1 KB ID:	185017
    Used foil to prefent glueing the rearpart to the hull.
    Click image for larger version  Name:	20241115_145736.jpg Views:	0 Size:	46.3 KB ID:	185018
    Lined it up with the hull and glued all parts together.
    Click image for larger version  Name:	20241112_190705.jpg Views:	0 Size:	45.6 KB ID:	185019
    While the glue was drying started to work on the conningtower, made both scopes, navigation scope at the front and the attackscope at the back, and a hohentwiel radar antenna.
    Click image for larger version  Name:	20241112_190714.jpg Views:	0 Size:	49.7 KB ID:	185021
    Still have to make the splitterscreens and some more antenna's, have to alter the schnorkelhead because it's too big accourding to my drawings.
    Click image for larger version  Name:	20241118_190601.jpg Views:	0 Size:	50.4 KB ID:	185022
    This is the result of the magnetic coupler, the rear-end is connected to the hull
    Click image for larger version  Name:	20241118_190613.jpg Views:	0 Size:	54.7 KB ID:	185023
    By pulling it apart you can access the internals of the rearpart, had to make some slits on the hull coupling since the shafts will stay inside the rearpart.
ID:	184885 Counter rotating shaft in the ITC Halibut toy submarine from the 1960s
    Still enough space on the motor shaft to press fit a spur gear that intermeshes with another spur gear on the opposite shaft...
    Option 'B', Manfred. One motor, two counter-rotating shafts:
    Romel,
    Nope. Put 'em away wet and they'll be good for a season. When they go tits up, replace 'em. I got hundreds of 'em. Cheap as dirt too.
    Romel,
    Are you going with David's dual direct drive or a single motor with split gearbox?
    Thanks for the info, that will be usefull when maidening the boat, for now everything is in pieces on the bench.
    Did some work on the conningtower, placed the guns, this is the first stage of pimping up the tower.
    Made the outlines on PCB board for the magnetic fastening of the rearpart
    Guide pins soldered and ready for glueing the magnets, when done i can prep those pieces for glueing them to the hull parts
  • Davjacva
    Manfred, you are presenting a level of work that is always on the level of a fine watchmaker. Here's some input into it's operation as I drove the one Dave built. I was skeptical as to how it was going to operate, but it operates surprisingly well for such a small package, and the external forces on the planing surfaces are not that great, so you can get away with a lot.
    Ah, i can see it now, used the bowplanes mistakely for the stern, since they are pressfitted i can change them to the way it's suppost to be, thanks for the tip guys
    Manfred, are you using the bow planes at the stern?
ID:	184804 Click image for larger version
    Mission accomplished, sir. Again, you take me back to school. You're the most inovative guy I've had the pleasure of knowing in decades! I'm overrated... you are the real deal.
    We both stand on the shoulders of other gifted builders David, simply showing what is possible or not.
