Bibers scale 1:35
    • 1554
    Bibers scale 1:35
    As promised i did some digging in the archives, buckle up,here we go
    I must mention all the work on the Bibers is done by my mentor, the only thing i did was bringing them back to live.
    These are the mold derived from the Verlinden kit, he used them to make the glassfiber hulls
    Those are the Bibers after i did some work bringing them back to live.
    Just before i started opening them up
    You can split them open by removing some small screws, the made a metal flange on both halves, used RTV to make a watertight connection
    As you can see he placed some small gears to get some more torque from the motor, and used as a transitions to the height of the propulsion shaft, i suspect it is rated 3:1
    He made some cradles to hold both servo's, one for the rudder and one for the divingplanes.
    Those servo's where burned out, you can see the bulge at the bottom, the reason it happens is, to much voltage at the servo's, he used a batterypack rated 6V, those servo's are rated 4,8 V, i changed the packs to 4,8 V on both bibers, luckely the size of the servo's are allmost the same which i had in stock.
    To lubricate the shaft he placed two nipples, by removing them both you can fill it up with some light oil,usually this is done once a year during maintenance.
    View on the rearpart with both the rudder and divingplanes.
    The Biber disassembled, as a ESC he used a old servo print, replaced them both by modern ESC's to get more control on the speed, he used a 6 channel receiver, to control both Bibers i can use channel1-3 for one biber and channel 5-6 for the other.
    Replaced both servo's which i had in stock, they are clamped together with some small screws.
    Inside both torpedo's are the batteries, for long storage you can unplug them, the same connection is used for charging, switching on the Bibers is done by a magnetic switch which is hidden in one of the torpedo's.
    You can drive them for about 1 hr, more than enough time, they are dynamic divers and work surpricely well under water.
  • Schmitty1944
    • Mar 2021
    • 136
    Amazing. Thank you for showing and explaining the details. The radial split is a pretty clever approach. There is a fantastic amount of detail in those models. especially at such a small size.
    Unless there is something I don't see there is no gear reduction. All of the red gears have the same number of teeth. It is a very clever way to get the shaft at the bottom of the motor though. I did find your youtube videos "Reviving the Bibers, part 1 and 2" it looks like they have plenty of power and speed.
    I also found another youtube video of a 1/35th biber that is RC based on the Italeri kit. Not many details are given. It has a working ballast tank. It appears to use the torpedos propellers for propulsion and steering and maybe does not have moving controls? Included is a link to the video, note this is not mine and I don't know who the builder is but it may be from Canada?
    How do the seals work for the servo outputs in your Bibers (and Seehund)? You mentioned O-rings. Where are they located?
    Many thanks
    Jason.
      • 1554
      Jason,
      You're right about the gears, i've checked it out on the pictures, only done to get it to the height of the shaft.
      As for the O rings, they are only used at the divingplanes, the rudder is sealed off by grease, he used injectionneedles with a tight fitted rod and a grease chamber, pretty much the same layout on the seehund.
      • Schmitty1944
        • Mar 2021
        • 136
        Here are a few photos of the 2nd Biber I built based on a "toy" submarine. This one is completely working with a functional ballast tank. I just need to finish the details and paint and I was going to make more scale looking propellers for the torpedos.
        Click image for larger version  Name:	thumb_58782.jpg Views:	0 Size:	7.0 KB ID:	178960Click image for larger version  Name:	thumb_58783.jpg Views:	0 Size:	6.7 KB ID:	178961Click image for larger version  Name:	thumb_58784.jpg Views:	0 Size:	6.6 KB ID:	178962The ballast tank exposed on the bottom is obviously not very scale but it does work well. You can see the toy it is based on in the background and the controller on the left is my own modified version of the round blue controller that came with the toy with the buttons arranged to make more sense for the Biber.
        Jason​
