Midget submarine "Biber" (display model)
  • DrSchmidt
    • Apr 2014
    • 1359
    Before starting something bigger again I need something quick that I can build right ouf the box, well, 99% out of the box. So I went for the 1:35 scale "Biber" kit by Italeri that I found about 1 year ago. And I have to say, I love the kit. Nice details, good details, PE and two figures. Fun build.
    I started off with the two halves of the hull and added two gauges left an right at about the height of the windows (like in the original). Fabricated from sprue and then connected with piping made from solder wire. The displays were made from left over decals from the kit. Primed in gray and the painted white gray.
ID:	170585Click image for larger version
    The cockpit dashboard got additional, 3D-printed valves that were again connected with solder to simulate pipes. The seat was just painted and stained....
    Then the hull was glued together with almost no seam or gap.
    Then the rudder...and firts parts of one G7a torpedo.
    The bilge keels, propeller axis and the dive plane....
    Seams are filled and firts PE details are on the boat. This is the result of three days. I like it.....
  • DrSchmidt
    • Apr 2014
    • 1359
    In case someone should need references for the Biber cockpit....
    • DrSchmidt
      • Apr 2014
      • 1359
      After the first steps being pretty easy and straight forward, the installation of the guide rails for the torpedos was a much more demanding task. Allot of little PE parts had to be bend in shape and glued in place. But with the markings on the hull, I got a decent result. Windows are in, cockpit roof is on, and some additional small parts found their place. Hull is getting ready for primer....
ID:	170639Click image for larger version
ID:	170640Click image for larger version
      • DrSchmidt
        • Apr 2014
        • 1359
        Primed the boat and gave it the Vallejo neutral gray base coat. Then I applied a gray filter and sealed everything with a gloss clear coat. Looks rather flat....
        To make everything pop, I started accentuating details using gray, black, and white washes. Some ruts and oil staining to give a more real feel to everything and voila:
        Next some dry brushing and then I'll leav it at that....torpedos, stand, name plate and done.
        • DrSchmidt
          • Apr 2014
          • 1359
          Finished the weathering of the Biber. I kept is subtle as the boats were not long lived and out of the water most of the time. Decided to go for the G7a Torpedoes as I just prefer the more complex tail fins. Painted the main body in Vallejo Metal Color steel and the warhead in machine gray. The detonator is 3D-printed as it just looks better than the ones out of the kit. The stands are printed as well and then everything was mounted on a mahogany-stained maple board. Type plate is printed and painted as well. I like it. Also put the two sailors of the kit together and started painting them. i hardly ever paint figures. For that it turned out O.K, so far...
ID:	170727Click image for larger version
            • 3618
            Good luck hitting something Lol
            Crews need this https://youtu.be/h_IEk12RyZ8
            • DrSchmidt
              • Apr 2014
              • 1359
              Yeah...a bit cross-eyed.
              • DrSchmidt
                • Apr 2014
                • 1359
                Finished the build of this little boat and I had allot of doing it. Nice little kit and I highly recommend it although it's currently out of production. I painted the figures included with the kit, and I'm rather pleased with the outcome. I will never become a figure painter, but for this display it's more tan O.K.. The figures give a very good sense of size and as the Biber is being displayed in the same box as my XXIII, this also gives a good impression of size as well. So on to my next Project, the U.S.S. Discovery XD-1 from the famous movie 2001. So nothing to show here ...
ID:	170778Click image for larger version
                  Excellent build Andreas!
                  Impeccable workmanship and skill, and the figures display very nicely with the Biber! Looking forward to your next build..
                  "Firemen can stand the heat."
                  • DrSchmidt
                    • Apr 2014
                    • 1359
                    Thanks allot! As I said, the next project is a Sci Fi model and as this is a submarine forum, it's not suited for this audience ;-)
                      • 13834
                      With what you have to show/teach us, I'm sure Bob would make an exception.
                      • DrSchmidt
                        • Apr 2014
                        • 1359
                        I could give it a try...
                          • 13834
                          Please do, Doctor.
                          And, to prime the pump, I'm going to post some of my Science Fiction project to my 'Today's Work' thread. Let's see if that garners howls of protest, or indications of interest and appreciation.
