Seehund Scale 1:35
    • 1661
    Seehund Scale 1:35
    I've started to work on the Seehund, the hull was made by my mentor, he also made the provisions for steering the rudder and diveplanes and placed a E motor complete with the shaft to propel it.
    I presume he started with making a mold of the Verlinden Seehund, the dimensions of his hull are exactly the same, in the past i bought the same kit, i can use the PE parts and other parts to make me a working Seehund.
    This is the hull he has made, same dimensions as the Verlinden kit.
    Rearpart with the E motor and rods used to steer both the rudder and the diveplanes.
    It can be split by removing two hidden M2 screws.
    This where I am now, placed two micro servo's, hooked up the receiver and took a print from a normal servo as a ESC, still have to do some testing.
    Manfred, several queries about your creation.
    -What motor are you using?
    -How do you actuate the rear diveplane and rudder with that tiny space?
    -How do you seal your shafts and control rods?
      • 1661
      Romel,
      The E motor is a 6V motor from a old servo, don't know the brand
      Same way as with the big boats, only using rods 0,6 mm thick to steer everything
      Little O rings used at the propellorshaft and diveplanes, the tip of a seringe with a vaselinechamber used for the rudder, it has to be watertight as possible, no high waterpressure involved since it will be a dynamic and surface runner.
        I thought you were running the E-motor wet.
          • 1661
          It will be a dryhull, just like the Bibers, you need all the room you can get with this tiny boats.
            • 1661
            This week i played around with the releasemechanism to shoot torpedo's, pictures
            This is the torpedo i want to use, they are shorter are my normal torps, normally i use them to fire from the reartube of my type VII.
            I made some movable clamps which will hold the torps in place, this is the secured position.
            From the front it looks like this.
            This is the unlock position, releasing the pin which keep the holders at their place.
            A look from the front with both holders released.
            It is not scale, but seen from this angle it doesn't look too wrong to me, now i have to link up the release mechanism to a servo, back to the tweezers.
              • 1661
              This was interesting, destroyed two servo's and had to order both some new ECS's and servo's,
              A microservo placed at the keel, just enough room to play.
              I ended up with building a plate which can hold the servo, used a 0,6 mm rod to connect the servo to the releasemechanism.
              After several times fitting i could determen the lenght and shape of the rod, believe me, big boats are better.
              And finally placed into his final position, the trick was, using as much tweezers you can get and a headlight to give you some light during the operation.
              Wiring up the new ESC, the old one gave me flutter on the servo's, this a big no no, because it will launch the torpedo's pre-mature.
              Since i have a slight disorder for hatches, i made me this, complete with the glass dome of the Verlinden kit.
              And yes, it can be opened. this is done with a special reason.
              I added a inner tube with a connector at the bottom.
              Modified a figure with a connector at the bottom, the idea is, once you put this guy into the hatch it will activate the boat by closing the circuit, the inner tube is also used to vent the boat when she has to get used to the temparture of the water.
              To be continued.
                Madness!!!!
                You intimidate us all!
                  • 1661
                  Madness indeed, the first one who tells me building small boats is easy can run for his life.
                  On the other hand me love Rube Goldberg, i like to build things with a challence, so a seehund capable of shooting torps is a plus, the scale that is another story.
                    • 1661
                    I decided this week to play with the torpedo's, to be more precise, finding out where the magnets have to be placed,
                    Ended up with keeping the body of the torp at his place with tape, measured up what the exact position of the body will be.
                    By using a multimeter i could see when the magnet would activate the torp,
                    Once the torp is launched it will run away under it's own power.
                    To keep the magnets at their place i first used CA and ended up with 2K epoxyglue.
                    You can see the magnets at their place on both sides of the servo, believe me it was not done quick, the room inside is terrible and you need three hands to get things done.
                    Also found out i made a mistake with the hatch, the hinge had to be at the front, took the soldering iron and corrected it. the result can be seen in the first picture of this post.
                    Together with the kit come some resing parts which make up the scope and antenna, this will be duplicated into copper, just to be sure it will not be knocked off, so back to the cave for some more work.
                      • 1661
                      Due to medical issue's the Seehund was on hold, i've been operated and back on the road to recovery, i can show you guys the results before everything went wrong,
                      As you buy the model they have included some resin parts which represent the scopes, the are too fragile to place on the boat.
                      Made me some copper parts as replacement.
                      The copper parts soldered on the PE deck.
                      A dryfitt on the Seehund to see if eveything matches before i can glue the deck down.
                      And this will be the general layout which will be placed inside the Seehund, from left to right, receiver, ESC, 2 servo's for both the rudder and rear dive planes, the 3 thrd servo is inside the hull for launching the torpedo's.
                      Rebuilded the old transmittor to a spare one, the old one sometimes defaulted itself from nothing, you don't that want to happen when driving your boat.
                      For now i have to make some provisions to add some lead inside and come up with a secure way to place the batterypack inside, also reprogramming the newly rebuilded transmittor for my boats and testing all functions of both the transmittor and boats.
                      • SSBN659
                        • 418
                        Sorry to hear about your operation but wish you a speedy recovery. I'm always amazed at what you come up with in the models you do.
                        Best,
                        Will Rogers
                        SSBN659
                          • 1661
                          Thanks Will, it will take some time, as for the models, i allways want to know what is possible or not, i've got me a serious Rube Goldberg syndrome, if it won't work i've got me some nice static models.
                            • 1661
                            I has been some time since my last post, they diagnosted cancer with SWMBO, she's operated and recovering, giving me time to put on the lights in the Cave,
                            First i will post the progress which i made last summer,
                            First i added some flat lead to give me some weight inside the hull
                            Made the charging points in the keel, marked them with the right polarity, inside the plus connection there is a diode present, so there will not be a short between the connections when put inside the water.
                            Finding a way to place some of the batteries ,first made a mockup with some ducktape, those two are present at the rear, the others will be placed inside the front of the hull
                            It was a near fitt, had to remove some material from the left flange to make it happen.
                            Ended up with those copper holders, secured them with superglue and backingsoda.
                            Time to get all the stuff inside, believe me, i rather build bigger boats, you need three arms to get is right.
                            Had everything inside and the servo of the torpedo release burned out during testing, so i had to take apart the boat to replace this.
                            Replaced the servo by this one, had to fiddle this one inside, a pain in the ass.
                            This is where i stand now, slapped on some paint and she is sealed with the use of RTV, ready to do some watertight testing this weekend.
                            Procedure of testing will be simple, weigh the boat when dry, weigh the boat when wet, leave it for some time in the water and weigh it again, when no leaks the weight will be stable, when not, i have to search where the leak is coming from.
                            • goshawk823
                              • Oct 2010
                              • 262
                              Best wishes for a speedy recovery for your wife.
