WTC from repurposed materials
    Just sharing photos of my WTC which I made from various repurposed materials. The cylinder is a section of plastic tubing 9 .5 inches long, with a 1.5 inches (38mm) OD and 1 27/64 inches (36mm) ID. It is used as sort of track for small motorized cars. Click image for larger version
    The endcaps are plastic blocking plugs used to seal the ends of stainless steel or aluminum pipes like railings and furniture legs.
    They have a couple of flanges that help grip the inside of the pipes.As they were a couple of millimeter larger than the nternal diameter of the WTC I took a file and slowly ground the edges til it was able to slide in without binding. Click image for larger version
    I then ordered some 36mm x 30mm x 3.1mm O rings and placed it between the 2 flanges. This is the endcap inserted at the end of the cylinder. Fit and sealing was good. Click image for larger version
  • cgbillb
    • May 2018
    • 182
    Redboat219
    Where did you get the items, you used? I like to build my own WTC as well
    Bill
    Athens Ga.
      I got the tube from the toy section of a local department store. As for the blocking plugs and o-rings, I ordered them from China.
      • Sam Victory
        • Sep 2021
        • 391
ID:	156563Click image for larger version
        Try this, the drifting bucket for fishing, if you want to make your own WTC with simple materials. The diameter of the drifting bucket suitable for RC submarines varies from 4cm to 8cm.
        V
          Fit inside the 1/35 X-craft.
            V
            Do they sell these on Shopee or Lazada?
            • Sam Victory
              • Sep 2021
              • 391
              Sorry, I don't know what these shopping sites you've mentioned, but at least I've found them on other sites.
              V
              Plastic Fishing Float Tube 40/50/60cm Length Thick Protective Storage End Caps|Fishing Float| - AliExpress
              • cgbillb
                • May 2018
                • 182
                Wow thank you guys, I will google them, Thanks again.
                I have two sub hulls, but no WTC and just can't afford to purchase any. WTC.
                Have the CSS Hunley and the U-505
                Thanks again.
                Bill
                Athens Ga.
                • cgbillb
                  • May 2018
                  • 182
                  Guys
                  I just order a 65cm tube form Miss Amazon, be here around Jan 1st free shipping.
                  Thanks, again
                  Bill
                  Athens Ga.
                  • neitosub
                    • Nov 2021
                    • 161
                    V
                    One thing to keep in mind is that the plastic used in these commercial water tight tubes are often polyethylene or HDPE and do not bond well with adhesives. If they’re made from ABS then you’re in luck.
                    • cgbillb
                      • May 2018
                      • 182
                      OK thanks I will do some test work when it gets here with my difference adhesives.
                      And go back to the site and read up on it some more.
                      Bill
                      Athens Ga.
                      • Sam Victory
                        • Sep 2021
                        • 391
                        Usually are PC or PVC, with very good resistance to pressure, ABS I have not seen. If you want to make your own WTC by simple materials I believe it is a good choice, choose the right adhesive, I believe they can succeed.
                        V
                        • cgbillb
                          • May 2018
                          • 182
                          Thanks Sam, I will play with differ adhesive, working on my U-505 while I am waiting on my tubes to arrive.
                          Have an older WTC I rebuilt for it.
                          Bill
                          Athens Ga.
                          • neitosub
                            • Nov 2021
                            • 161
                            V
                            I was referring to the endcap material being polyethylene or HDPE. The tubes themselves could be polycarbonate or acrylic. Although for the application they’re intended for, I would imagine them being made in polycarbonate.
                            • cgbillb
                              • May 2018
                              • 182
                              OK thanks, I will check it all out when I get the tube. Just order a waterproof Motor from Bob.
                              Bill
                              Athens Ga.
