The next sub on the printer - 1/72 Typhoon
  • Halcyon66
    • Oct 2021
    • 28
    #31
    Many thanks.
    Regards,
    Gregory
    • Halcyon66
      • Oct 2021
      • 28
      #32
      This thread went quiet, is the model still progressing?
      Regards,
      Gregory
        • 810
        #33
        Yes it is.Had a few issues to work through with the files/prints but it is moving forward now. It is going to be a beast!
          • 1821
          #34
          Right on Steve!
          No doubt about it, that is your kind of boat for sure! 3D printing!! You are the master!
            • 810
            #35
            Another hull section printed. One word. Enormous. Makes me want to go back and make another 1/72 LA class boat. Gotta have the set, right?
            Click image for larger version  Name:	20211211_130030.jpg Views:	0 Size:	75.2 KB ID:	156746
            It will be the full length of the 8' table when done.
            • Monahan Steam Models
              • 755
              #36
              Wow that is a big boat! The submarine is looking really great Steve! You really have printing in ASA dialed. From the photos the finish looks great!
                • 1168
                #37
                Steve, what kind of primer do you use? I’m learning airbrushing, but I prefer can primer.
                Casey
                  • 810
                  #38
                  Thanks Nick. This one is ABS. I print ASA and ABS using the same settings.
                    • 810
                    #39
                    Casey
                    Hey Casey, I use a High Fill Polyurethane automotive primer called Finish 1. It is a two part primer so not air dried. Cures quite quickly and is very easy to sand. I spray it on with a cheap HVLP sprayer I got at Walmart. Cleans up with Lacquer Thinner. It is more expensive than rattle can primer but the results are superior so to me it is worth it. I will not go back to the rattle cans except on small parts. The primer actually creates a hard shell that gets into any pores and helps seal and lock it all together. Good stuff.
                    • Halcyon66
                      • Oct 2021
                      • 28
                      #40
                      Looks awesome.
                      Regards,
                      Gregory
                        • 810
                        #41
                        Almost done....
                          • 1168
                          #42
                          Enough room for a small house.
                            • 1821
                            #43
                            Almost done....
                            Steve,
                            Your Typhoon is magnificent! Just for my information. How many print hours do you have in the Typhoon at this point? That boat is going to displace a lot of water! Great project!!
                              • 810
                              #44
                              Steve,
                              Thanks Rob. At this point I have lost track on how many hours it has taken. At this scale I had some issues with the files printing in their stock condition. Randy Sanders has helped with some different files but then I lost a couple parts due to something that really had me puzzled initially causing me to have to change how I printed the parts and as a result I gave up trying to keep up with it. I have been printing it on and off since 9/28.
                                • 1821
                                #45
                                You have come so far with it Steve, I hope you and Randy can get those files squared away! It would be a sham if you could not finish it.
