The boats longitudinal centerline is the datum reference line for the draft numbers. The designed waterline on modern American attack boats is rarely (I almost said 'never') parallel with the the boats longitudinal centerline. A striking example of this skewing of the waterline to the boats centerline is the LA class where the bow is seven-feet higher than the stern while at rest on the surface (true for the flight-1's, the later varients sat lower in the water).
On bodies of revolution, where most of the hull is of constant diameter, its convenient to use the base-line, the bottom of the hull, as the reference line for the draft numbers. The length of the bottom rudder does not enter into draft number placement on the upper rudder.
