Engel Type IXD2 First commission build
    Looks very good
    Thank you sir.
    Latest progress.
    I continue to work on detailing the sail. David has been resin printing additional parts and making improvements to existing ones. I just completed adding lights. They are super micro LED's so I was able to keep them from being too bulky and actually look like they should.
  • DrSchmidt
    Looks very good
    Another update. Tonight I got the handrail added that goes around the sail. Aside from a couple small bits the brass work is mostly done.
    I got the deck detail added. This extra kit that David got for it was a good decision.
    Originally posted by Das Boot
    Very nice. What is the story on the destroyer? Lindberg or SB?
    It is a Bancroft 1/72nd Fletcher class. I got it from Motion RC
    Someone needs to bring a printer to the Subfest in September and give us clueless folks a lesson.
  • tifosi12
    I hope you'll keep the documentation up once it gets to the nasty bits: connecting the rudder, props and elevons
    Those are the parts I always struggle the most with.
    Today I got the resin printed guns and other detail parts from David who I am building this for. I also got the ladders made. It's progressing nicely.
  • a1965l
    Following with interest. I have a SS 1/48 type IX hull that will get attention, someday, always nice to get motivation.
    Moving right along. The sail lower deck rail is now on it. I used some fine wire to secure the upper rail to the lower rail for soldering.
    Got the rails mounted on the hull.
    Liking your brass work Steve! Very well done!
    Thanks Rob! It's possibly one of the more tedious parts of the build. The stanchions that came in the kit were intended to secure straight down through the deck but they mount on the side on a type IX so I had to remake every one from scratch. If I can sort out the sail lower deck rail with the hand rail that goes around the sail I will be home free.
    Got the upper deck rail built for the sail as well as the second rail for the hull deck. I built wooden jigs to hold the stanchions while I soldered them up which worked well but it was still a PITA! I am just glad they have turned out as good as they have so far. The sail lower deck rail is next. Note: I have not yet mounted the hull rails. They are just sitting on the hull in the last photo.
