HMS Astute 1/144 conversion
  • bassplayer1
    • Mar 2010
    • 244
    I started this little gem just for a brake. So far so good !
    Hi Bassplayer.
    What ballast system will you be using? Also how did you separate the rear dive planes?
    • bassplayer1
      • Mar 2010
      • 244
      Hi Bassplayer.
      Hi, peristaltic pump and a bladder. Sharp razor blade.
        Thank you.
          • Jan 2020
          • 1028
          What size SD are you using? Its looking good!
          • bassplayer1
            • Mar 2010
            • 244
            58mm OD by 360mm length
              • Jan 2020
              • 1028
              Thanks! Looking forward to your build!
                Not much annular space around the WTC for foam or weights.
                • bassplayer1
                  • Mar 2010
                  • 244
                  I have about 6mm and enough room in bow and stern, see how it goes.
                  • bassplayer1
                    • Mar 2010
                    • 244
                    Just finished, charging the batteries and I'll do some test tomorrow.
                    • bassplayer1
                      • Mar 2010
                      • 244
                      Some progress. Here is some photos and a video.
                        Looking good Bassplayer.
                        Did you use the kit's pumpjet propulsor or did you fabricate a new one?
                        Regarding your WTC, I see you used bellows for your control shafts but how did you seal your motor shaft?
                        • bassplayer1
                          • Mar 2010
                          • 244
                          Thanks, I used the kit's propulsor,works fine! For the motor shaft I used grese, no problem so far. The reason being I can't find a cup seal of 3mm ID down here.
                            Bassplayer, any videos or photos of the shakedown cruise?
                            • bassplayer1
                              • Mar 2010
                              • 244
                              She is trimmed, seats nicely surfaced and submerged but I have a problem with the pump. The stupid thing sometimes it works, sometimes it doesn't ! I ordered a new one and see how it goes !
