S.M. U-5 - a long term project
  • DrSchmidt
    • Apr 2014
    • 1393
    I still love those WWI era submarines from the Kaiserliche Kriegsmarine. Simple designs form the time when folks learned how to build subs and how not to.... I did the S.M. U-1 quite a wjile ago. I plan to get it up and running again this winter. There's a very good S.M. U-9 built bei Bernhard Wenzel which is also the basis of the plastic kit by Das Werk which will be released this January. Just out of fun I decided to start sketching the U-5. The U-5 wasthe class boat for U-5 to U-8 and the first design that feaured more than one boat. I like the simple, elegant lines....so let's see where this goes. Here are the first CAD-drwaings. Hill and sail.
    Click image for larger version  Name:	image_45566.png Views:	4 Size:	123.1 KB ID:	145894
    Click image for larger version  Name:	image_45567.png Views:	3 Size:	97.0 KB ID:	145895
    • Oct 2017
    • 1097
    Yes, i like the lines of these early subs,too. However i like the streamlined, sci-fi like projects of the late Imperial Navy of 1918 even more. Always believed the later U-Boats beeing a step backwards to more conventional designs. Good luck with your project and schöne Feiertage!
    • DrSchmidt
      • Apr 2014
      • 1393
      Danke.....I plan to draw a UC II baot as well. That will be one of the futuristic designs but much more complicated to model.
      • roedj
        • Sep 2008
        • 564
        I may be confused as to exactly which boat you're planning to build. Attached is a picture of what I believe to be Austro-Hungarian SMU-5. For you trivia fans that's probably Kapitan von Trapp up top - yes that von Trapp - but not singing here. I only bring this up because the two boats - this and your drawing - don't look the same to my eye.
        Kapitan Corrector
        • DrSchmidt
          • Apr 2014
          • 1393
          It's the German U-5. In WWI bot Austria-Hungary and Germany were monarchies. Thus the abbreviation SM (Seiner Mejestät; "her majesty's"). The one you show is a Holland type boat.
          https://en.wikipedia.org/wiki/SM_U-5_(Germany)
          • roedj
            • Sep 2008
            • 564
            OK, I think I understand. You want to build the German U-5 and I'm talking about the Austro-Hungarian SMU-5. Please see link...
            Is that correct?
            Thanks for your patience and help,
            Kapitan Confused
            • DrSchmidt
              • Apr 2014
              • 1393
              Yes, that's correct
                • Oct 2017
                • 1097
                Could be useful. However i believe you already have good plans.
ID:	145948Click image for larger version
                  • Oct 2017
                  • 1097
                  Hi Andreas! What happened to this project, any progress?
                  i recently took my zero bubble u 23 from the shelf ( that will be build with a TOP RUDDER !!!) and began assembly preps.
                  greetings from Dessau-Roßlau
                  Jörg
                  • DrSchmidt
                    • Apr 2014
                    • 1393
                    Not much progress.....
