3D printed 1/72nd scale Los Angeles class submarine
    • 825
    The LA files from The Nautilus Drydocks in 1/72 scale printed in PLA+. 5-1/2" beam. 60" long. Its a good looking boat. I will seal it inside and out with high fill polyurethane primer.
  • secrtwpn
    • Feb 2012
    • 182
    Where did you get the stand? I'm looking for one for my 1/72 Skipjack........................
      • 825
      Yeah, it is just a foam Robart plane caddy.
      • coryhenry
        • Jul 2020
        • 156
        NIce print, now what is going on with the Typhoon in the background?
          • 825
          That is an epoxy fiberglass hull pulled from a set of molds that my friend Darrell Sprayberry has. Him and another guy made the molds years ago. I am waiting on the resin appendages but basically it is a future project.
            • 825
            I taped the openings from the outside and then sloshed polyurethane primer inside to seal it up and added the stern plane yokes. She's ready to start filling and priming.
            Click image for larger version  Name:	Image_1598118647.jpg Views:	0 Size:	63.1 KB ID:	142939
              • 825
              Lol. I had a knot removed from my thumb.
                • 825
                Sanded with 80 grit it is now ready for some Evercoat Rage filler and then a coat of PU primer. There is a good possibility that I could have this one ready for the regatta in Cohutta next month as well.
                  • 825
                  Ready for primer.
                    • 825
                    First coat of Finish 1 Polyurethane high fill primer is on and it looks good. Lots of sanding ahead.
                      • 825
                      Gut that thing!
                      Lol! That's a good one.
                        • 825
                        Second coat of primer is on. Turned out great. Only minor sanding required and then I will paint it.
                        Click image for larger version  Name:	20200826_213737_copy_2016x1512.jpg Views:	0 Size:	65.3 KB ID:	143071
                        Click image for larger version  Name:	20200826_213720_copy_2016x1512.jpg Views:	0 Size:	62.0 KB ID:	143072
                          • 3746
                          That is really coming along nicely!
                          • coryhenry
                            • Jul 2020
                            • 156
                            Which way are you going to cut it?
                              • 825
                              It's a bayonet style hull so it already separates in two places. One just ahead of the sail and this one aft.
                              Click image for larger version  Name:	20200826_234612_copy_2016x1512.jpg Views:	0 Size:	63.7 KB ID:	143079
