Gorgeous work, Steve! I'm going to love seeing this thing in the water!
As if I don't have enough projects - 1/76th Ohio'ish sub
You're underwater at periscope depth and your sail hits a boat. The superstructure pops off the hull. Bad ju-ju!
It wouldn't kill you to put a retaining screw up forward to prevent inadvertent separation of the superstructure from the hull proper.
So there! Another *****!
DavidLeave a comment:
Update: The hull work is now basically done aside from some small detail work. The missile deck is attached and the fairwater planes and sail are installed. I designed and 3D printed some spacer rings to spread the hull in the hatch area as PVC pipe contains some serious stresses that are relieved if a section is removed like I did. The walls bowed in along the length of the hatch as a result. The spacers corrected the issue. The spacers also have a lip that allowed another small bracket I designed and printed to catch the lip and slide forward about 3/8" thus locking the hatch down snug. The best part is that no tools are required to secure it. Essentially the hull is now ready for finish work but the next step is fitting all of the running gear. It has really turned out good so far. I do still need to do some blending of the forward missile deck to the hull and there will be some minor trim work and filling to do but it does look like an Ohio.
Wheel looks great. Now, fix the two vertical stabilizers that hang off the outboard ends of the horizontal stabilizers -- the leading edge is a true vertical, not swept.
Rivet Counter extraordinaireLeave a comment:
It is a master piece in the making. Looks great and will look just as great in the water!Leave a comment:
Steve,
That hull looks great! That's a BIG Sub! I think you will have another master piece in the making! Thanks for the photos and up dates!
Back on this. The fiberglass parts are done. I had to make some slight changes to the missile deck to make it narrower and ride higher but it worked out well. I also got the stern surfaces and fairwater planes installed. Next up I need to design and 3D print some spacer rings for the hull. So far it is lookingpretty decent.
Lol! Thank you David.Originally posted by He Who Shall Not Be Named
What a rare and wonderful situation it is when you have a peer who shares your skill sets and interests. Synergy on display. I have a similar situation with Kevin Rimrodt and Bob Martin. With the right number of cooks you can achieve a wonderful soup.
You and Darrell are not only practicing, but also advancing the Craft. I applaud you both.
(now switching back to A-hole mode... click!)
