As if I don't have enough projects - 1/76th Ohio'ish sub
He lives for that kinda stuff. I'm a retired airdale.. his stuff bounces off me like cannonballs off the Constitution.Leave a comment:
I would suggest giving George Sitek a email at GT Sitek props in UK give him your specs (Prop dia, Boss shape, no of blades (7),shaft Thread size you want eg M5, etc) he does superb Brass work at a reasonable price. I got the props (and Aluminum rudders) for my USS California CGN36 made by him from a photo...
You managed to get past the reverse rotation but you just have to go and poke him don't you? Can't let a sleeping dog lie? Well, OK then but you will have to bear the consequences of your actions alone. ;o)👍 1Leave a comment:
Just wait till he sees the oversize monstrosity I'm gonna put on the Charlie...👍 1Leave a comment:
Too funny!!Originally posted by He Who Shall Not Be Named
I only got so much venom per strike, pal. Take a number, sit down and wait your ****ing turn! Don't worry, you're still at risk.Leave a comment:
HEY! You didn't bag on me for using a wrong rotation prop on my 688.... or perhaps you were just overwhelmed by it's sheer bulkOriginally posted by He Who Shall Not Be NamedTwo problems with that propeller:
Unless the photo was flopped, it spins the wrong way. Most American single-screw submarines have the wheel rotating in a clockwise direction (right-hand pitch) going ahead, when looking forward.
Also, the pressure face of your wheel appears to be under-cambered, it should be convex to almost flat at the tip. The blade section of almost all non super-cavitating marine propellers is of almost symmetrical camber throughout the span.
DavidLeave a comment:
That thing is a monster! OK, I didn't want to pester you but where does one acquire an Ohio prop that is roughly 1/76th scale or around 100mm in diameter since I assume such doesn't already exist but you have surprised me at every turn so I am starting to think that anything is possible.Originally posted by He Who Shall Not Be Named
I think you would be better served going with the OHIO class wheel (different scales I built for the Crimson Tide movie) illustrated here. Also in the shots are the wheel for the bad-guy AKULA miniature (the one that 'imploded' at the end of the flick).Leave a comment:
Shhh...don't tell anybody but it is actually described as a Russian sub propeller. ;o)
Unfortunately I have not had much success finding a file for a proper one. Seeing as how this project is more of a POC build for me which is part of a larger plan, it will do for now. I agree it is not accurate. Outside of the basic dimensions and shape I have not endeavored to make it accurate to scale but Ohio'ish. I cannot even determine if it is the correct size. My next one will be bigger and more accurate. This one is helping me to learn better molding materials/practices from my friend Darrell Sprayberry.
You sir have an uncanny eye for detail. Something to be admired.Leave a comment:
