1/72 688 class
  • a1965l
    • 147
    1/72 688 class
    Hello again. Recently struck up a deal and wound up with 2 subs, a SS type IX and the above mentioned 688. I also got a WTC, set up for twin shaft intended for the IX but since the 688 is closer to being ready, I think we'll start with that.
    Sadly, there was some damage in shipping. One of the stern planes got knocked off, and the shaft bent. I'm not certain that the Yoke isn't bent as well, but I don't see any way to remove it from the boat and look at it up close.
    That's one big boat. Lots of room in there for fat hands and such. You'll have to pardon the state of my "workroom" we're still in the process of moving stuff into the house and getting set up. Eventually, I'll have a garage out back with a proper workbench and shop, but that's at least 6 months away at this point.
    Nice clean break.
    I played with it yesterday for a while, but couldn't get the angle on the shaft just right. The fixed portion of the plane still has movement when you move the flap, so it needs more tweaking.
    There are a few things I need to figure out. I have a Dumas Akula that's set up as a static diver. It's sail is large enough to hold the float and flapper valve for the snorkel. The 688's sail is way to narrow, plus the mechanism for the fairwater planes is in there. I'm thinking about making one of the actual masts into the snorkel, but can't come up with a way to put a gooseneck right at the end and hide it. Otherwise I'm gonna get a slug of water into the air system and really, I'd rather not do that. I see there is an alternative setup, but we'll cross that bridge when we come to it.
    WTC fits nicely. No issues at all there. So, let's make some saddles. I do have a 3d printer and knowledge of autodesk so...
    So close. Well, back to inventor for some modifications... thats' just the first couple of layers, done that way for a template. The actual saddle will be about 3/8 inch wide. AS for saddles, how many do I really need? Do I need to support the cylinder front and back and in the middle? I was thinking 2, positioned fore and aft of the ballast tank, and tight to it to keep the cylinder in place would be enough. Oh, and I need to relieve those supports to allow water to flow through, given that there are no flood vents right under the ballast tank..
    And for down the road....
    Make that sail removable -- machine screws running up from within the hull and into the base of the sail. With that MSD you received a vertical type snorkel -- you can shave the sides of that float to clear the inside of the sail.
    I would recommend you reconfigure the hull break to be more like this:
ID:	138021Click image for larger version
ID:	138022Click image for larger version
    This will give you easy access to the stern yokes, propeller shaft, MSD, and sail linkage. This is the classic Z-break: radial break at the bottom bow, a radial break at the upper stern. Only one fastener required.
    Don't sweat the current 'shop'. Any port in a storm, pal!
    Four saddles: two for the 2.5" forward dry space, and two for the after dry space. Would it kill you to actually cut out those saddles with your own two hands!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    The Horrible
      Our new cylinders will have more than enough OOmph to push that boat along, and there is ample room for up to 6A of LiPo's, but I'm worried about your ballast tank. That's a big boat, and Tim has that 3" tank cut at what looks to be something in the neighborhood of 8 or 9". For something of that size, I'd have recommended the 3.75" diameter tank with about 8" of length. You may find you'll be shy on freeboard, but the ability to swap the cylinder between boats may offset that in your mind.
      • a1965l
        • 147
        He bought the cylinder to fit the IX, and given that I have to mod the cylinder for the 688, I think swapping probablly wouldn't happen. I suppose this would be as good a place as any to debate the pros and cons of getting a overall larger cylinder. I like room... that's why I stayed an airdale. If I went with a larger diameter motor and batt cylinder and then a larger ballast tank, true, it would be limited to just that boat, but I don't see that as a huge downside. It's just money.. if I run out, they'll print more.
        A definite yes on making the sail removable.. and what you suggested is pretty much I was thinking. The snort float is gonna have to be mighty thin to fit in there. I'll get a picture in a bit. As far as the hull cut.... that's a really beamy hull, and getting even my fat hands back aft isn't all that hard. That opinion might change once I put flotation foam in and get some supports installed for the cylinder, though.
        The reason I can't pull the pitch yoke is that the movable portion of the stern planes is fixed with an outer hinge. I'd need to be able to pull the fixed portion as well, and I really don't feel like ungluing it and taking a chance on damaging the hull.
          So, what would make you happy is a cylinder with 3" fore and aft cylinders, and a big honking 3.75 ballast cylinder in the middle? If so, you're in luck, I'm producing masters for the MB and unions for the 3" version, I should have a production unit ready for you in a few weeks. Will that work for you? Here's some shots of that work:
ID:	138030Click image for larger version
          Yank out all that linkage back there. I'll fix you up with yokes that well permit easy attachment to the control surface operating shafts:
Name:	DSCF3384 - Copy.JPG
ID:	138032Click image for larger version
ID:	138033Click image for larger version
ID:	138035Click image for larger version
          • a1965l
            • 147
            David....
            I think I will take you up on that offer. (the cylinder, that is) I can stash the other cylinder away in the IX to await it's turn. Just for you, I actually cut something out by hand today. Well, hand on the sabre saw, but.. don't judge too harshly, I don't have my belt sander here yet and it does need a little lovin. Plus some cover'in
            Seems to fit OK... although the camera seems to have gotten a little confused about exposure...
            As to the yokes.. I don't know if you can tell in the top picture, but the rudder yoke is actually one of yours. Here's what I have for the stern planes:
            hard to tell if it's bent, would surprise me if it wasn't given the blow it must have taken to knock the palne off the sub. Either way, I'll keep playing with it and eventually I'll get it straight. I hope. Although I gotta say, your design looks sturdier.
            Gonna be a tight squeeze getting that snort valve into the sail...
            And look.. feathered cat food. I don't know who he thinks he's kidding.. those birds would flat out kill him.
              OK. That's the 'horizontal' type snorkel head-valve. You need the 'vertical' type. And I'll fix you up with a pair of the largest yokes I have for the stern.
Name:	059 - Copy.JPG
ID:	138059Click image for larger version
ID:	138060Click image for larger version
ID:	138062Click image for larger version
ID:	138067Click image for larger version
ID:	138063Click image for larger version
ID:	138064Click image for larger version
ID:	138065Click image for larger version
ID:	138066Click image for larger version
              Give me your mailing address and list any other goodies I can fix you up with. dmeriman@aol.com
              • a1965l
                • 147
                Probablly easier just to swing by.. I am local, after all.
                  make it happen
                  • a1965l
                    • 147
                    Excellent. I do not recall how to find you, although I've been there once before. Hows your weekend look?
                      This weekend is fine. 835 Holly Hedge Ave., Virginia Beach, VA 23452, 757-418-0779 Call first.
                      • a1965l
                        • 147
                        David, heading your way now, phone unanswered and mailbox full...
                        • a1965l
                          • 147
                          I hope everything's good on David's side...
                            I was here all day, in the shop or napping.
                            • a1965l
                              • 147
                              I must have the worst timing with phone calls... will have to try again. Land chores to do today, but possibly not all day. But that depends on what does or dosen't break while working...
