Building the Zero Bubble Model Design 1/120 Mike SSN
    • Oct 2017
    • 721
    #76
    Work went on with fully outfitting the ZB-1 dive cylinder with Servos, Speed Controller, Receiver and setting up the Sheerline Valve system. i used flat battery plugs instead of soldering the fuses to allow quick replacement.. I added one more Servo for independent operation of the forward planes and replaced the provided pushrod seals for 2,3mm diam. pushrods with the common Engel-Type Seal for 2mm pushrods. to install those in the existing openings i made two sockets from stainless hat-nuts that were glued in place with resin. i also introduced a new drive shaft as i learned David did not use 4mm shafts with a reduced diameter around the cup seal like my original one anymore but a shaft with consistant 4mm diameter. i also wanted to change the shaft length.
ID:	154698Click image for larger version
ID:	154699Click image for larger version
ID:	154703Click image for larger version
ID:	154702Click image for larger version
ID:	154706Click image for larger version
ID:	154704Click image for larger version
ID:	154701Click image for larger version
      • Oct 2017
      • 721
      #77
      some more pictures of the outfitting of the cylinder. After initial testing i replaced the large Endcap O-Rings with bigger and wider ones as over time the existing ones lost seal and i had leaks on both sides during initial testing. to do so, i had to enlarge the grooves. i made a simple depth gauge for a fine file and removed the material carefully, using Edding marker in the groove to identify the areas still beeing not deep enough after every filing cycle. i also shortened the lexan tube and milled in a wider cone at both end faces.
      Click image for larger version  Name:	20210520_235900.jpg Views:	0 Size:	66.8 KB ID:	154709Click image for larger version  Name:	20210523_231223.jpg Views:	0 Size:	73.1 KB ID:	154710Click image for larger version  Name:	20210724_144813.jpg Views:	0 Size:	72.0 KB ID:	154711Click image for larger version  Name:	20210724_144841.jpg Views:	0 Size:	69.0 KB ID:	154712Click image for larger version  Name:	20210523_231247.jpg Views:	0 Size:	73.1 KB ID:	154713Click image for larger version  Name:	20210724_144831.jpg Views:	0 Size:	71.6 KB ID:	154714Click image for larger version  Name:	20210725_142318.jpg Views:	0 Size:	70.5 KB ID:	154717Click image for larger version  Name:	20210725_121739.jpg Views:	0 Size:	69.2 KB ID:	154718Click image for larger version  Name:	20210725_142346.jpg Views:	0 Size:	73.8 KB ID:	154719Click image for larger version  Name:	20210731_153949.jpg Views:	0 Size:	90.7 KB ID:	154720Click image for larger version  Name:	20210731_153943.jpg Views:	0 Size:	60.1 KB ID:	154721Click image for larger version  Name:	20210731_153927.jpg Views:	0 Size:	64.8 KB ID:	154722Click image for larger version  Name:	20210801_141211.jpg Views:	0 Size:	67.5 KB ID:	154723
      Click image for larger version  Name:	20210423_221811.jpg Views:	65 Size:	63.3 KB ID:	154730Click image for larger version  Name:	20210811_212317.jpg Views:	65 Size:	61.5 KB ID:	154731Click image for larger version  Name:	20210811_212232.jpg Views:	64 Size:	70.7 KB ID:	154732
        • Oct 2017
        • 721
        #78
        To mount the Cylinder in the hull i used two PP brackets that were bolted down on the hull and two indexing screws at the stern endcap. Those correspond with two L-brackets on the inner hull sides.
ID:	154739Click image for larger version
ID:	154738Click image for larger version
ID:	154741Click image for larger version
ID:	154735Click image for larger version
ID:	154736Click image for larger version
ID:	154734Click image for larger version
ID:	154745Click image for larger version
ID:	154737Click image for larger version
ID:	154743Click image for larger version
ID:	154744Click image for larger version
          • Oct 2017
          • 721
          #79
          Finally it was time for testing, however without the ballast tank that had not been constructed yet. The boat sat upright on the pool bottom. I decided to add some masts to bring in more details. So i made some after consulting Pictures of the original vessel for a proper combination. I used brass for the mast heads from rods and sheets that were soldered together. Antenna and attack scope are 2mm stainless steel, the Radar and Satellite Navigation array received 3mm Stainless tube over the 2mm rod to thicken up the mast appropriately. all that was CA`d together and mounted on an ABS tray just under the Sail.
ID:	154748Click image for larger version
ID:	154770Click image for larger version
ID:	154771Click image for larger version
ID:	154772Click image for larger version
ID:	154763Click image for larger version
ID:	154773Click image for larger version
ID:	154774Click image for larger version
ID:	154775Click image for larger version
ID:	154776Click image for larger version
ID:	154749Click image for larger version
ID:	154750Click image for larger version
ID:	154752Click image for larger version
ID:	154751Click image for larger version
ID:	154753Click image for larger version
ID:	154754Click image for larger version
ID:	154755Click image for larger version
ID:	154756Click image for larger version
ID:	154757Click image for larger version
ID:	154758Click image for larger version
ID:	154759Click image for larger version
ID:	154760Click image for larger version
ID:	154761Click image for larger version
ID:	154762Click image for larger version
          sandblasting prior to painting
ID:	154766Click image for larger version
ID:	154777Click image for larger version
ID:	154778Click image for larger version
ID:	154779Click image for larger version
ID:	154780Click image for larger version
            • Oct 2017
            • 721
            #80
            Now that the look was about right, i turned my attention towards ballast tank construction. I used PVC Pipe, PVC Endcaps and slosh baffles. the inlet pipe was made from brass and press-fitted into the tank with a piece of silicon tube so i could remove it for emptying the tank after a run and allow for some maintenace of the otherwise entirely sealed tank construction. again, i used a PP bracket for the installation. also drilled some holes to vent the air. tried to persue the pattern on the genuine KOMSOMOLETS. Click image for larger version
ID:	154791Click image for larger version
ID:	154792Click image for larger version
ID:	154793Click image for larger version
ID:	154794Click image for larger version
ID:	154795Click image for larger version
ID:	154796Click image for larger version
ID:	154797Click image for larger version
ID:	154798Click image for larger version
ID:	154782Click image for larger version
ID:	154783Click image for larger version
ID:	154785Click image for larger version
ID:	154789Click image for larger version
ID:	154786Click image for larger version
ID:	154790Click image for larger version
ID:	154788Click image for larger version
ID:	154784Click image for larger version
ID:	154787Click image for larger version
ID:	154799Click image for larger version
              • Oct 2017
              • 721
              #81
              A small sidenote concerning my Robbe Futaba F-14 radio: As mentioned before, i changed the receiver of the ZB-1 cylinder to accept the F-14 instead of the simple Wfly 4ch device. My F-14 is specifically set up for controlling rc submarines with the Navy twin stick and two linenar modules. One major disadvantage is the lack of a servo reverse switch common to modern radios that in the past prevented me from using it for more than one model at once as the servo direction had to be determined internally on the mainboard of the F-14. In case of a change it had to be opened and set up again. However as being of modular design, that old system offers many slots for upgrades and so i installed 8 double-pole/three position switches both to change the servo direction and shut off unused controllers. I also found some information in the internet of others having done so before. As of now, it's one for all ! Click image for larger version
ID:	154939Click image for larger version
ID:	154938Click image for larger version
              A pair of three pole switches will be installed up-left in the future to change between the blue proportional and the linear controllers in the center.
              Jörg
                • Oct 2017
                • 721
                #82
                Hello!
                I have recently been notified by DavidH that i did not conclude my build report. It seems i actually forgot about that over some very important business issues at the end of 2021, even though i thought i already wrote about that! Actually i am not quite sure there is Page 7 of this thread missing at all. Whatever....
                So the following describes what i did in Autumn and Winter 2021...
                I experimented withe several balast tank sizes and construction that basically differed in capacity and weight in order to find a working design, together with different SLA battery sizes.
                Click image for larger version  Name:	20210910_215129.jpg Views:	0 Size:	65.3 KB ID:	160650Click image for larger version  Name:	20210911_144935.jpg Views:	0 Size:	72.9 KB ID:	160652Click image for larger version  Name:	20210910_223506.jpg Views:	0 Size:	68.2 KB ID:	160651Click image for larger version  Name:	20210911_150825.jpg Views:	0 Size:	70.5 KB ID:	160653
                This is the last of the 3 balast tanks and as of now the operational model, that allows me to run at the surface slighly lower than waterline and a bit stern heavy to have enogh distance beetween water surfae and propeller. I decided that would be "scale" enough after having found some actual pictures of Komsomolets at that depht.
                One thing i found really bad about the original Sheerline tank was the inability to easily vent it after a run due to its all-sealed cunstruction. as you can see in the last picture there is a piece of silicon rubber protruding from the endcap around the brass pipe inlet. this is the seal of that brass pipe. the entire pipe can simply be pulled out of the tank for maintenance and put back in using the perforation of the center slosh baffle as guidance. My approach, self-sealing with rising inner pressure.
                  • Oct 2017
                  • 721
                  #83
                  I continued with bassin tests, first outdoors and with the wheather turning colder and the pool gone, indoors in my test bassin, a relict from building the Delta II SSBN years ago.
ID:	160655Click image for larger version
                    • Oct 2017
                    • 721
                    #84
                    ...and in the garage:
Name:	20211015_233224 (Custom).jpg
ID:	160660Click image for larger version
Name:	20211015_233215 (Custom).jpg
ID:	160661Click image for larger version
Name:	20211015_233209 (Custom).jpg
ID:	160662Click image for larger version
Name:	20211015_233238 (Custom).jpg
ID:	160663Click image for larger version
Name:	20211015_233202 (Custom).jpg
ID:	160664Click image for larger version
Name:	20211015_233404 (Custom).jpg
ID:	160665Click image for larger version
Name:	20211015_233140 (Custom).jpg
ID:	160666Click image for larger version
Name:	20211015_233246 (Custom).jpg
ID:	160667Click image for larger version
Name:	20211015_233458 (Custom).jpg
ID:	160668Click image for larger version
Name:	20211015_233537 (Custom).jpg
                      • Oct 2017
                      • 721
                      #85
                      ...some more...
Name:	20211015_234135 (Custom).jpg
ID:	160671Click image for larger version
Name:	20211015_234128 (Custom).jpg
ID:	160672Click image for larger version
Name:	20211015_234219 (Custom).jpg
ID:	160673Click image for larger version
Name:	20211015_234305 (Custom).jpg
ID:	160674Click image for larger version
Name:	20211015_233907 (Custom).jpg
ID:	160675Click image for larger version
Name:	20211015_234347 (Custom).jpg
ID:	160676Click image for larger version
Name:	20211015_234436 (Custom).jpg
ID:	160677Click image for larger version
Name:	20211015_234601 (Custom).jpg
ID:	160678Click image for larger version
Name:	20211015_234658 (Custom).jpg
ID:	160679Click image for larger version
Name:	20211015_234824 (Custom).jpg
                        • Oct 2017
                        • 721
                        #86
                        ... and more...
Name:	20211015_234845 (Custom).jpg
Name:	20211015_235730 (Custom).jpg
Name:	20211015_235819 (Custom).jpg
Name:	20211015_235842 (Custom).jpg
ID:	160685Click image for larger version
Name:	20211015_235937 (Custom).jpg
Name:	20211016_000026 (Custom).jpg
ID:	160687Click image for larger version
Name:	20211016_000151 (Custom).jpg
Name:	20211016_000325 (Custom).jpg
ID:	160689Click image for larger version
Name:	20211016_000354 (Custom).jpg
ID:	160690Click image for larger version
Name:	20211016_000409 (Custom).jpg
                          • Oct 2017
                          • 721
                          #87
                          ... even more...
Name:	20211016_000430 (Custom).jpg
ID:	160693Click image for larger version
Name:	20211016_000604 (Custom).jpg
ID:	160694Click image for larger version
Name:	20211016_000750 (Custom).jpg
ID:	160695Click image for larger version
Name:	20211016_000812 (Custom).jpg
ID:	160696Click image for larger version
Name:	20211016_000904 (Custom).jpg
ID:	160697Click image for larger version
Name:	20211016_001018 (Custom).jpg
ID:	160698Click image for larger version
Name:	20211016_001056 (Custom).jpg
ID:	160699Click image for larger version
Name:	20211016_001201 (Custom).jpg
ID:	160700Click image for larger version
Name:	20211016_001301 (Custom).jpg
                            • Oct 2017
                            • 721
                            #88
                            Some picture of the internal configuration. Note this was taken with the larger SLA in place and a smaller and lighter ballast tank installed:
Name:	20211016_001750 (Custom).jpg
ID:	160703Click image for larger version
Name:	20211016_001802 (Custom).jpg
ID:	160704Click image for larger version
Name:	20211016_001810 (Custom).jpg
ID:	160705Click image for larger version
Name:	20211016_001928 (Custom).jpg
ID:	160706Click image for larger version
Name:	20211016_002132 (Custom).jpg
ID:	160707Click image for larger version
Name:	20211016_002309 (Custom).jpg
ID:	160708Click image for larger version
Name:	20211016_002406 (Custom).jpg
                              • Oct 2017
                              • 721
                              #89
                              Sick of looking at the midnight glowing of that widowmaker? Here are some shots on an unexpected sunny October day:
ID:	160711Click image for larger version
ID:	160712Click image for larger version
ID:	160713Click image for larger version
ID:	160714Click image for larger version
ID:	160715Click image for larger version
ID:	160716Click image for larger version
ID:	160717Click image for larger version
ID:	160718Click image for larger version
ID:	160719Click image for larger version
                                • Oct 2017
                                • 721
                                #90
                                Some pictures of the ZB-1 Watertight Cylinder provided by Zero Bubble Model Design after upgrading to the Corona receiver. As of now, i am using a 5-channel configuration with seperate control of bow- and stern planes. During bassin trials, i used a simple 4-ch WFly radio, now changed for the F-14. I will see if i need to install a levelling module for automated stern plane operations and maybe an external BEC if necessary. Spring has arrived in Germany and i hope to find time for proper "sea" trials.
ID:	160723Click image for larger version
ID:	160724Click image for larger version
ID:	160725Click image for larger version
ID:	160726Click image for larger version
                                Best regards & stay healthy!
                                Jörg
