U-552 Trumpeter 1/48 static
  • bianco64squalo
    • Apr 2017
    • 94
    #46
    Work in progress....
    • bianco64squalo
      • Apr 2017
      • 94
      #47
      Now I'm working on some inside conning tower equipments, starting from UZO; in posted photos the kit piece and the head of my one.
      I'm not totally satisfied, but it's starts looking good..
      Cheers
      • The Boattrainman
        • Mar 2016
        • 443
        #48
        You're doing great work, not sure some of that detail would last on my R/C model.
        From the angle of the first photo, not sure if the UZO is in line with the two scopes as it should be or is it off-set to port. I had a major job to rectify this as many kit and upgrade manufacturers persist with this mistake.
        From my photos etc. the UZO has to be in the dead centre, see the below for more details.
        http://amp.rokket.biz/docs/the_wolf_pack_compr.pdf
        • bianco64squalo
          • Apr 2017
          • 94
          #49
          Hi Boattrainman,
          the first photo is not my model....I know UZO was in central position, and not offset to port ( the Wolfpack article is my bible....), as in posted photo...
          It will be very difficult to modify the photoetched deck, but surely I'll do...
          Cheers
          P.S. : I'm remaking by scratch the handle ring on UZO head, too much flat in photoetched part, with a plasticard rod one...
          • bianco64squalo
            • Apr 2017
            • 94
            #50
            UZO finished...
            • The Boattrainman
              • Mar 2016
              • 443
              #51
              Terrific work!
              • bianco64squalo
                • Apr 2017
                • 94
                #52
                I'm now working on attack periscope mounting...
                I don't like very much the photoetchings features: they are too much flat; I prefer use plasticard...
                • bianco64squalo
                  • Apr 2017
                  • 94
                  #53
                  • bianco64squalo
                    • Apr 2017
                    • 94
                    #54
                    Not yet finished, but it starts to look something...
                    • bianco64squalo
                      • Apr 2017
                      • 94
                      #55
                      Still working on conning tower elements...
                      In the last photo is visible the wrong position of UZO on photoetched deck: I don't know exactly how modify the photoetched deck: opinions welcome....
                      • bianco64squalo
                        • Apr 2017
                        • 94
                        #56
                        Completed also the pressure conning tower cap....
                        Now I'm working on inside conning tower walls; Trumpeter repetaed the Revell's errors, and so, inexplicably, the air inlets ducts are less wie then the outside gratings....so I decided to enlarge the ducts...
                        I also removed the plastic vertical planks from inside tower walls, because I want to do them from wood, as real....
                        Stay tuned....
                        • Scott T
                          • May 2009
                          • 414
                          #57
                          Awesome scratch building. How did you form the domed conning
                          tower Cap? Hollow out curve or form curve?
                          • bianco64squalo
                            • Apr 2017
                            • 94
                            #58
                            Hi Scott,
                            the domed conning tower cap is a piece from kit; unfortunately I did'nt take a photo of the piece before starting to modify it, but it was very poor, wrong in curvature ( too much prominent ) and without any particular ( see the photo I posted, taken from Trumpeter's site )....
                            • bianco64squalo
                              • Apr 2017
                              • 94
                              #59
                              Still working on conning tower, inside and outside....
                              Nothing yet glued, only dryfitted....still a lot of work to do....
                              I'll make the wood stripes on side walls of conning tower with real wooden planks....
                              Cheers
                              • cgbillb
                                • May 2018
                                • 182
                                #60
                                Great work we can compare Subs as we go along
                                Bill
