Seaview
    Be aware that brushless motors don't answer quite so quickly to reverse commands as their brushed equivalents. They have to be stopped first then restarted the other way, so there is a slight (and I do mean slight) delay.
    The brushless ESC I linked to in an earlier post is reversible.
    My quick answer is Yes, you will need to make sure the brushless ESC does reverse.
    OK, now, this will be the $5000.00 question. I use both port and starboard motors independantly to help steer this thing and turn it around. Can a brushless motor go forward and reverse?
    Originally posted by Kazzer
    Does the speed make much difference to a model submarine? It's a log in the water at best.
    If the difference was a within 500RPM I'd say no, but with more than 50% increase RPM, it will make a big difference. Depending on the props and/or gearing being run, the motors may bog down and overheat, and as Albion pointed out draw a lot more current. It would be an excellent motor for converting an old 3.0 SD to 12 volt operation though as the RPM matches up very well with the 7.2v speed 400.
    Originally posted by Albion
    yeah, more amps
    AH! I guess I'll get Mr. M to do his amp stall test on these new motors, so we have a definite amperage result on them.
    (Something I forgot to get done)
    yeah, more amps
    Going by the specification (17500RPM at 12 volts) that motor is a different wind to the MFA version which is 12000RPM at 12 volts. I don't know how those two compare in specification with the Graupner motor.
    We have a new selection of motors. These are already fitted with suppressors.
    http://www.caswellplating.net/380-motor-12volt.html (Don't order from here - this is our new site and isn't quite ready)
    I mentioned before that the 12 volt speed 400 long can motors are no longer available from Graupner but they still offer the 7.2 volt 400s.
    MFA sell the 12 volt 5 pole 385 motors, if that's of any help.
    Thanks jlday1256
  • jlday1256
    Damn skippy...nice boat!
    Yours truly putting her together at Devils Den.Click image for larger version
ID:	65158Click image for larger version
ID:	65159Click image for larger version
ID:	65160Click image for larger version
ID:	65027Click image for larger version
ID:	65028Click image for larger version
ID:	65029Click image for larger version
ID:	65030Click image for larger version
ID:	65031Click image for larger version
Name:	seaview underway.JPG
ID:	64900Click image for larger version
Name:	Seaview on bottom.JPG
ID:	64901Click image for larger version
Name:	Seaview bubbles.JPG
ID:	64902Click image for larger version
Name:	Seaview back of sail.JPG
ID:	64903Click image for larger version
Name:	Seaview again.JPG
