Is the spring used to absorb vibration? Maintain pressure to prevent the ends from popping out? Please help the less informed!
Newbie no more - Building the Revell 1/72 Gato
Jay, You radical! You rebel! Trying a new idea? Come on share (with pictures please!).
Now the fun part starts, finishing the hull/deck joint. I've sanded so much my shoulder and elbow are aching. I'm taking my little girl with me to the hobby shop to get some square alum tube for the drive shafts. Just a little experiment with two part spring loaded drive shafts. It should work slick if there is enough room.
JayLeave a comment:
JayLeave a comment:
Completing the deck fastening. Following David’s direction of locking down the deck, I placed his upper deck foundation piece and checked fit. Before I drilled, assuming I know where the hole is to be placed, I wanted to mark the hole that the screw would come into the inside and see how it lined up.
I used a mechanical pencil and pushed out a long length of graphite.
Then placed the pencil into the hole were the screw would go and moved the pencil around until I felt like I had a good mark.
I do not think the photo came out well enough, but the inside of the deck there is a slight flattening or ghost of the hole on the other side of the deck. The upper deck foundation piece lined up perfectly. Here you can see the hole that Revell has placed for the rear flag mast.
Using a 1/16” drill, I drilled out the hole.
Put the screw in and the upper deck foundation. It lined up perfectly. I think David might know what he is doing.
The kit comes with a slotted 2-56 machine screw, I personally like phillips and so I replaced the screw. It is 1/32” smaller diameter head and I wanted to save the weight that David’s screw would have added plus scale wise the phillips is 2.25” smaller (tongue placed firmly inside cheek).
Following the directions and tips from the dvd, I roughed up the areas with sandpaper and CA’d the upper deck foundation onto the hull.
Time to counter sink the hole. I used a hart bur about the size of the crew head counter sunk the hole.
Placed the deck on and secured it with the scew.
Nice and secure.Leave a comment:
David do not think it is just you I am waiting on. I have several things on order. There are servos coming in, snort pumps (just came in), tools, screws, nuts, and LiPo charging Bag. Thank you for getting the part in the mail. You are DA MAN! (no buttocks kissing intended) LOL -ouchLeave a comment:
Ouch! Take your pills and do what the Doc says. Parts are ... as they say ... in the mail.
David,Leave a comment:
@David - You know the main reason. There are several reasons for jumping around. I am waiting on some parts and not wanting to do nothing, I am working on different things - all of which need to be done, just not in the order I would like. I am also researching for the next phase (detailing) once the core dive system is up and running. I am thinking through on challenges that I need to resolve (like WTC placement, dual SNORT install), but the main reason is I am medicated with pain pills. I was wrestling with my family, on my back on the floor, my wife was tickling my feet, the dog was pulling my hands, and that left my midsection open for a jumping attack by my son. He landed on my chest (instead of my belly - like he usually does), cracking and spraining my ribs, thankful they did not get broken (recovery can be unto 6 months for that). Apparently a sprain/crack hurts as much as a broken rib, according to the doctor. Either way, it hurts like a son-of-a-gun. The recovery on a cracked/sprain is up to 3 months. Thank you for asking. LOL - ouch, it hurts to do that.
@Jay - These were done on Photoshop, but I am familiar with Illustrator, Photoshop, Flash, and most of Adobe's line of software. How's the flood holes coming along? I appreciate that we are both building in parallel. It is nice to see how you have worked through areas and how we both hit the same road bumps.Leave a comment:
While I have a little down time (there is a story behind it, but I will not bore you with it), I am looking to add some details to the deck. One of the things I want to add is the exhaust and footholds on the rear sides. I took the line drawing from the Revell Gato instructions and superimposed images of different ships, including the USS Cobia. The results are interesting (for me at least - could be my state of mind). Here, take a look and let me know what you think.
USS Bashaw SS-241
Next is USS Cobia SS-245
USS Greenling SS-213
USS Haddo SS-255
The ship is layered over the line drawing with transparency so you can see both images with the differences between top image (Real Gato or Drawing of another) and the bottom (Revell Gato Line Drawing). If you have a side view of your completed Revell model kit, please send it to me. I would like to overlay your model with their own line drawing, just to see.
Happy Thanksgiving to those that celebrate this holiday.
As a side note, I am working on more build information, but for the meantime I may be jumping around until parts/info/healing comes in.
(my observation here is not correct, if the real sub is photo'd even a few degrees of perpendicular it will shift the alignment of items on deck. So look at the above post with a grain of salt)Leave a comment:
Tom, thank you so much for the bottom plan. My wife had the I.T. person for her company do her magic and emailed it back to me in a printable page by page layout. Very nice indeed! After downloading a copy of Adobe Illustrator, we couldn't figure it out. Just not my field of experience.Leave a comment:
Jay,
Thank you for letting me use the die, I will return it soon. If you want, I can print up the plans and send them to you. I put it into Adobe Illustrator, made sure the length was correct, then printed it using tiled printing and put a 1" to 1.5" overlap. that way i could line everything up. I really appreciate your generosity and regret that I did not offer the saw blade instead of pointing out where I got it. You taught me a lesson, thank you.Leave a comment:
