Looks like it could be a winner, but I might pass for the moment.
Japanese BI I-25 in 1/72
If you look hard enough at the photos, in the first photo you can see the emergency buoy being pulled along after it has been released and in the second photo you can see on the rear deck the hole where it lives. Both of the emergency systems worked very well. I will post some photos of the way it is set up as soon as I can.Comment
Finally got around to scratch building the twin anti aircraft guns in the conning tower.
And this is the emergency gas system.
As you can see it is operated by a push-rod from inside the water tight thingy, but both the gas cylinder and valve are mounted externally to the water tight thingy. The gas cylinder can be removed or exchanged in seconds and because it is clear it is easy to tell how much gas is left and it takes the guess work out of refilling.
Just enough weathering. I see so many over do it. When I look at photos of the original subs, I see light weathering for the most part. Once in awhile I see heavy wear and tear. This looks fantastic! Cheers!If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.Comment
Hi all, I picked up a cheep Cam corder today and gave it a test.
The video is a bit boring but it will give you a good CLOSE look at the i25.
There is video of both sides as well as a top view.
Let me know what you think I can do to improve the model.
That is great work. You asked for comments so maybe a little weathering on the
towers roof. It probably is right with the deck weathering but in the video it look
closer to a large freshly painted roof. Maybe foot path wear.
It really does look great.
ScottComment
Thanks Scott, you are correct in what you say about the roof. I didn't even think about the roof when I was weathering the boat.
I guess a large flat area like that with all sorts of things the birds could sit in/on and out of the way of human contact would soon get very messy. Add to that that because it was flat any water left up there would evaporate and leave the salt behind.
Mix the salt and bird droppings together add a little heat to open up any faults in the paint and away it goes.
Any other ideas?Comment
