Revell Gato
    Revell Gato
    Here are some shots from The Cave, with The Wizard showing the installation of tubes. Note the special plate he's made to align the tubes. These will be available in due coarse as an add-on product.
ID:	99829Click image for larger version
ID:	99830Click image for larger version
ID:	99831Click image for larger version
ID:	99832Click image for larger version
ID:	99833Click image for larger version
ID:	99834Click image for larger version
ID:	99835Click image for larger version
ID:	99836Click image for larger version
ID:	99837Click image for larger version
ID:	99838Click image for larger version
  • Anuci
    Banned
    • 165
    Magnifico, bravo, very nice work, I'm glad I never cemented my bow to the main hull. However, just wondering how much foam will be needed to offset the additional weight in the bow. Thanks for the peek shots.
      • 13984
      Thanks, Al.
      About two cubic inches of foam per tube, a bit less I think, I'll work up a firm answer on that soon. Believe it or not I'm producing a bow and stern torpedo launcher interface kit that will allow of installation of the tubes with the bow and stern sections already permanently bonded to the main hull. I'm almost at the point of tooling up the interface masters and from there I'll move on to make a commercially available kit for you guys. I'm awaiting some raw material from McMaster-Carr, then I can get underway with the orders and interface kit.
      • Anuci
        Banned
        • 165
        Sounds good, looks good, gotta be!!!!!!!!!!
