Torpedoe Size Information Help
  • george
    • Dec 2010
    • 731
    Hello, I had this posted in the General Section, 33 views and Nothing! So here goes;
    To ALL the membership. Could someone tell me what would be the size of a WWII British Torpedoe, U.S Torpedoe and a German Torpedoe that would have been launched from the various countries P.T Boats of that period in 1/35 scale, I just need the outside dimensions in 1/35 Please. If you have any pictures, that would be great as well. Would like to have some possible working scale like torpedoes for my 1/35 Italerie S-100, Vosper etc. boats.
    Thanks for Your Help.
    George
    George
    Too easy - here are some resources - take the dimensions and divide by 35.
    From wikipedia:
    here is the S100 page - http://en.wikipedia.org/wiki/E-boat
    here is the British Torpedo boat page - http://en.wikipedia.org/wiki/Motor_Torpedo_Boat
    here is the German Torpedoes data page from WW2 - http://en.wikipedia.org/wiki/List_of...oes_of_Germany
    here is the link to the British 21" series of torpedoes (533mm) - http://en.wikipedia.org/wiki/British_21_inch_torpedo
    here is the link to the US PT boats - http://en.wikipedia.org/wiki/PT_boat
    here is the link to the US torpedoes used in WW2 by PT boats Mk 8 torpedo - http://en.wikipedia.org/wiki/Mark_8_torpedo
    You will note that 21" or 533mm is pretty much the standard size used by all forces in WW2 and is pretty much the standard size used today by sub forces internationally with the exception of Russians and their friends who tend to use 26" / 650mm tubes.
    • george
      • Dec 2010
      • 731
      Hi Slats
      Thanks for your FAST help. Can you tell me if my math proceedure is right? I took all Measurements, coverted them to inches then divided that by 35 to get my sizes for my 1/35 scale torpedoes. Is that the right way to do this?
      Thanks Again Slats.
      George
        Hi Slats
        Thanks Again Slats.
        George
        Hi George,
        yes that's valid. All scale calculations are simply the real world (1/1 scale) divided by the scale you want. Weather you want to work in imperial measurements inches etc or metric is entirely up to you.
        But here is a tip : IME it is far easier to build scale features on scale models working in mm. Saves eye strain looking at fractions of an inch on a ruler.
        • george
          • Dec 2010
          • 731
          Hi Slats
          That is a Good Point.
          Thanks Again for All Your Help. BTW would you happen to know what the standard WWII Axis and Allied Torpedoe paint colours were?
          George
            Hi Slats
            George
            David paints his working 1/72 gas torpedoes Silver or Green (the former representative of WW2 fish, the later modern types). For working model Fish Silver is my preference as I can see them better. As far as did WW2 jobs have different colours to Silver a good guess would be yes, but stick with Silver as a default option.
            • george
              • Dec 2010
              • 731
              Thanks Slats, you helped alot.
              I see by a search that you in the past were looking at a Typhoon hull, what ever happened with that?
              George
                George
                Lost interest
                • george
                  • Dec 2010
                  • 731
                  Torpedo propeller question
                  From the WWII Torpedoes, they had counter rotating propellers, were they each two bladed or three bladed propellers. Also the inner propeller, the one near the body of the torpedo, did it rotate clockwise or counter clockwise?
                  George
                  • george
                    • Dec 2010
                    • 731
                    Need confirmation Help
                    Hello again
                    I am getting everything together to start to make my torps. One in 1/35 for my P.T boats and the other for a small 1/96 submarine so I need my math to be double checked.
                    I have decided to go with a generic one size for ALL my WWII PT Boats; US, British, German
                    1/35 -- 21" == 533mm dia. ==== 533 / 35 === 15.23mm dia. Finished
                    23.5` == 7162.8mm L ==== 7162.8 / 35 == 204.65mm Long Finished
                    1/96 -- 533 / 96 === 5.55mm dia. Finished
                    7162.8 / 96 === 74.62mm Long Finished
                    Question, how`s my math? Did I forget anything?
                    ALSO on WWII Torpedos, when you look from the rear of the torp. forward, the propellers near the torp. body, what direction do they turn? Then the outer propellers turn the opposite direction. How Many blades does each propeller have?
                    I can`t see them clear enough from my research pictures.
                    Please let me know.
                    Thanks for your Help.
                    George
                    • george
                      • Dec 2010
                      • 731
                      Hello
                      Any chance someone with experience can tell me if my scale math calculations are correct, please.
                      George
                      • gantu
                        • 428
                        Regards Gantu
                        • george
                          • Dec 2010
                          • 731
                          Hi Gantu
                          Thank You for the pictures. I finally was able to see in the last picture that there are 4 blades per propeller. Any chance you know which set turns in which direction? Looking from the rear of the torpedo forward?
                          Thanks Again Gantu
                          George
                            • 3764
                            Forward set is clock-wise and the rear most set is counter clock-wise
                            • george
                              • Dec 2010
                              • 731
                              Hi trout
                              Thanks for your help here. One more question, how is my math shown above? Did I do the conversion correctly? Let me know.
                              Thanks again
                              George
