When Putting a Flat on a Motor Shaft
    • 898
    When I File, Grind or Cut a flat on a motor shaft I use some blue tape with the sticky side out and the motor shaft poked thru. This way when cutting, the filings don't get sucked into the workings by the magnets - then when your done the tape is folded over the shaft and all the filings are wiped off with the tape-
    Click image for larger version  Name:	P6020033.jpg Views:	77 Size:	54.8 KB ID:	180538
    Click image for larger version  Name:	P6020034.jpg Views:	60 Size:	49.7 KB ID:	180539
    Click image for larger version  Name:	P6020035.jpg Views:	62 Size:	46.1 KB ID:	180540
    Click image for larger version  Name:	P6020036.jpg Views:	61 Size:	41.3 KB ID:	180541
    • 14014
    A similar 'chip-guard' employed to keep nasties out of the motor case:
      • ffr2608
        • Oct 2009
        • 348
        i put the motor in a ziploc and poke the shaft out a corner. Airtight.... I do hate dremeling those flats on the motors.
          • 898
          The plastic bag trick is also pretty slick-
          I too hate Dremeling the flats-I find that a file is easier to produce a flatter flat-the shafts are not hardened and there is less chance of going too deep-Just my OCD!
          Oh, on this subject...I forgot to mention that I line the flat up with the setscrew for the motor bell or anything else needed to reference where the flat is to facilitate finding its position when assembling.
          Click image for larger version  Name:	P6070037.jpg Views:	0 Size:	55.2 KB ID:	180577
