Casting Epoxy on Saltwater
  • Johnny Depth
    • Oct 2023
    • 34
    You can caste epoxy on saltwater. It floats on a saturated solution of saltwater. It cures completely in less than 48 hours. There is no cloudiness at all, no bubbles, and it is very strong.
    Specifically, I used Easy Cast Clear Casting Epoxy. Other casting epoxies will probably work just as well. I don't know. All I know is that this one does.
    Example: creating walls for a ballast tank...
    I took my cylinder, sealed off one end, filled it up to the position for the first wall with saltwater.
    I mixed the casting epoxy as
    16.20 grams Resin
    13.50 grams Hardener
    For my needs, this resulted in a ballast tank wall 1/4" thick.
    I poured it carefully on top of the saltwater and it floats.
    48 hours later, the first wall is done.
    Because you are casting on water rather than a hard surface, your casting has no scratches or imperfections.
    Repeat the process for the second wall.
    Another benefit is that the epoxy grips the polycarbonate very tightly.
    • 873
    Great idea for a lot of uses... I've tried casting resin on parchment paper...NG and casting resin on cured RTV... also NG
    How strong of a salt solution did you use?
      • 2026
      Wow... I definitely learned something new today. I'll have to try this!
      • Johnny Depth
        • Oct 2023
        • 34
        Thanks very much!
        I used a saturated solution just to be sure.
