Lathes
  • Ken_NJ
    I don't have room. Something that size is a dream.
    I have the vellum. Have a 36 inch t-square but no edge to run the t-square against.
    I just want to hear you yell. You can slap me on the head at Groton!
    Smile David!
    You pain in the ass! You said you didn't have any room!
    Stitch three sheets together and you have your party-boat. (Why do I bother with you dopes!?).
  • Ken_NJ
    Bigger. I'm designing 36-48 inch party boats.
    https://www.amazon.com/Yaheetech-Adjustable-Drafting-Drawing-Tabletop/dp/B07X1PKV6Y/ref=sr_1_5?crid=C11TPRILRM05&keywords=drafting%2Bt ables&qid=1701728055&sprefix=drafting%2Btables%2Ca ps%2C71&sr=8-5&ufe=app_do%3Aamzn1.fos.17d9e15d-4e43-4581-b373-0e5c1a776d5d&th=1
    And probably one of those sliding straight edges with the pulleys on the corner.
    You draw things less than 14 inches?
    I just screwed on this subject.
    Originally posted by Ken_NJ
    Only problem I have. I'm not using a traditional drafting table. I'm using a teak dining room table. I need a drafting machine with longer arms than what I can see on Amazon. Will keep searching.
    Or get a table top used for the purpose. But I have no room for another table.
    Make room!
    How about this, pal?
    Amazon.com: Frylr Inch A3 Drawing Board Drafting Table Multifunctional Drawing Board Table with Clear Rule Parallel Motion and Angle Adjustable Measuring System : Home & Kitchen​
  • Ken_NJ
    I don't have one of these! I've seen you use this elsewhere. It's a must have. Added this to my Christmas list.
    If anyone else wants one of these, this is the one I added to my list.
    https://www.amazon.com/Leather-Equally-Isometric-Leathercraft-Auxiliary/dp/B0BNMV854K/ref=sr_1_5?crid=WN1DPXR86HOP&keywords=spacing%2Bdi vider&qid=1701718366&sprefix=spacing%2Bdivider%2Ca ps%2C73&sr=8-5&th=1
    Also have to get one of those articulating drafting arms.
    Look under, 'drafting machine'.
  • Ken_NJ
    I like the idea of your method better! Casting. And using the tools I have. My preferred method being old school. Doing it with my hands. I'm with you!
    Not so much leaving it to a computer, sending it to a printer, walking away and it's done. Yes there might be some talent that way but less satisfaction. Better building it with your own two hands.
    Any idiot can push a mouse around and pick things off a menu and go, 'click'. Yikes!
    I'll use my hand AND my brain, thank you very much!
  • Ken_NJ
    Added the face plate to my tool list.
    Now I need to get into casting. Someday. You emailed me what to use from Alumilite.
    Or 3D printing.
  • Ken_NJ
    Or 3D printing.
    Ken,
    Excellent collection of measuring tools and quck-change tool holders.
    One last thing to add to that managery, that will increase your productivity -- and vital if you're to make rotating holding fixtures for your bulkhead work:
    A face-plate. This simple fixture attached to the head-stock of your lathe will rock your world.
    Master of Broken ****
  • Ken_NJ
    I went with this one 10 years ago. Never used it until recently after going on an accessory splurge. Can't do much without the proper tooling.
    Click image for larger version  Name:	IMG_1325 copy.jpg Views:	0 Size:	129.1 KB ID:	176321
    Click image for larger version  Name:	IMG_0626.jpg Views:	0 Size:	57.9 KB ID:	176308
    Inherited some of these from another model builder.
    Click image for larger version  Name:	IMG_0627.jpg Views:	0 Size:	50.7 KB ID:	176309
    Click image for larger version  Name:	IMG_0628.jpg Views:	0 Size:	49.2 KB ID:	176313
    Click image for larger version  Name:	IMG_0630.jpg Views:	0 Size:	42.9 KB ID:	176311
    Made a tool tray.
    Click image for larger version  Name:	IMG_2548.jpg Views:	0 Size:	55.4 KB ID:	176310
    And another center/chuck & tool holder.
    Click image for larger version  Name:	IMG_2549.jpg Views:	0 Size:	52.3 KB ID:	176312
    Click image for larger version  Name:	IMG_2550.jpg Views:	0 Size:	51.1 KB ID:	176316
    A Quick Change Tool Post (QCTP) is a must.
    Click image for larger version  Name:	IMG_2551.jpg Views:	0 Size:	57.2 KB ID:	176314
    After hand filing an endcap, got this 4 jaw independent chuck as recommended by David. Didn't use it on the endcap. But I now have it.
    Click image for larger version  Name:	IMG_2552.jpg Views:	0 Size:	54.6 KB ID:	176315
    This gauge holder comes in handy for more than holding gauges.
    Click image for larger version  Name:	IMG_2553.jpg Views:	0 Size:	51.8 KB ID:	176318
    Bit holders for the QCTP. The more you have, less pain in the a$$ to change the bits.
    Click image for larger version  Name:	IMG_2554.jpg Views:	0 Size:	58.3 KB ID:	176319
    Good for marking up the work.
    Click image for larger version  Name:	IMG_2555.jpg Views:	0 Size:	51.4 KB ID:	176317
  • SSBN659
    Copied Dave's idea and it worked very well for me.
Name:	Drill Press Lathe.jpg
    Will Rogers
    SSBN659
    Nothing intrinsically unsafe about an older machine, they work the same as the newer ones. Just don a pair of safety specs to catch any chippings that fly off whilst turning.
