The Perfect Circle Cutter?
  • STARK
    • Nov 2009
    • 243
    Ok so I see a tool that looks like a time saver for me, I get if I can asap! So I was on E bay and keep seeing this strange looking Red Box all over the tool section when I was looking for a circle cuter. It's made in China of coarse by a company Called DSPIAE.
    They came out with this Circle cutter (some time ago) that truly is Step less, they call it STEPLESS ADJUSTMENT CIRCULAR CUTTER, the MT-C.
    You haft to assemble the sucker but after you do that and figure out the Blade adjustment, Perfect Circles every time. The uses are many, Mask for wheels, Recessed tape mask on you model with primer, Insignia's, and other stuff. It's made out of Aircraft aluminum block, comes with stick on bottom anti slide tape, three tungsten steel cutting blades for different material cutting thickness, and just cool as hell. The center has a massif bearing in it that the cuter turntable glides on, and it should last a lifetime. A tad pricey but Worth it!
    https://www.scalemates.com/kits/dspi...utter--1102807
    What one Man can do, YOU can do too!
    Cool tool. I like it. Thank you!
    • STARK
      • Nov 2009
      • 243
      Youtube Video
