Fitting Everything Into Your SubDriver
  • DMTNT
    • Jun 2018
    • 297
    Or... trying to fit 10lbs of wires and connectors into a 5lb cylinder.
    I need some help from the wise on how to jam everything into the aft dry space on my 2 inch Sub Driver. I feel like it would be appropriate to call it the machinery space... Anyway. I have tried bunching all of the wires from the servos up with mini zip-ties, but I still found myself basically cramming all of this stuff in there and thinking there has to be a better way.
    So, I turn to the group. Curious to see how you all have overcome this problem of space - or a decided lack thereof.
    Thank you in advance!
    -Brady
    Dead men tell no tales...
    • 14013
    A good, valid, and timely question, Brady. And one that deserves a complete answer. Tonight I'll dig through my photos (and shoot supplemental ones if needed) that will help with the narrative to explain how to get all that **** into such a small space.
    Pleas, stand-by!
    • DMTNT
      • Jun 2018
      • 297
      Oh thank god. I will put my Dremel tool and cutting torch down, and slowly back away from the workbench until I hear more!
        • 14013
        "HANDS UP, WHERE I CAN SEE 'EM!"
        The Horrible
          • 898
          First they should change the name from sub driver to "blivit" (5lbs of &*!^ in a 3lb bag) My solution(might not be applicable for all) is to relocate as much equipment as possible outside the WTC and in the wet space. They have waterproof servos(real ones) that don't have to waste all that dry space (and if you don't trust them-belt and suspenders, mount them upside down and trap the air bubble so water can't leak in-but it wont.) I also use a waterproof ESC-those two items probably just saved 6 cu inches and a bunch of push rod watertight seals.
          • Scott T
            • May 2009
            • 414
            Found this while look for magnetic actuators.
            Need some of these miniature robots to run the boat.
            • DMTNT
              • Jun 2018
              • 297
              That is as unsettling as it is fascinating, Scott. I like it!
                • 651
                Reminds me of the story about a gaeocologist who decorated his hallway through the letter box.
                im trying to squeeze a lot of things into a dual drive 2.5” cylinder right now. I found that putting it down for a few days and coming back to it I see different ways to install things . I just bought a set of plugs and pins for my servos, so this afternoon will be trying to shorten the servo leads. Or more likely throwing out Servo s with short leads that don’t work anymore and fitting new servos
                  • 898
                  For the price of a handfull of servo extension wires (cheap on ebay) you can cut and solder any size you need-stagger the splices and use one piece of shrink for all 3 wires-they won't short c and it eliminates that unruly spaghetti..If the servo still works-don't toss it.
                    • 14013
                      • 898
                      Nice work-consider if you were to stagger the splices(to where they wouldn't touch if you squeezed them together uninsulated) then one piece of shrink tube would seal and cover them all eliminating that three separate splice look-and in tight quarters they do take up some xtra space and can lead to confusion. And whenever my fingertips work I try to do a soldered Western Union splice
                      BTW, I love that steam punk bench vice!
                        • 651
                        Worked slowly and checked my work at each step, I still have 3 working servos. $2.6 worth of parts, although nearly as many pins in the bin as I used.
                          Or you could not solder.....
                          I did this on my Type XXIII.
                          This is what it looked like at first.
                          Yikes....pretty scary.
                          Then I went and bought a crimper and some servo ends.
ID:	131144 With these tools I was able to cut the servo to the proper length and add a new end on it. No soldering.....which is a good thing for me.
                          The end result was a clean, orderly Sub-Driver.
                          • vital.spark
                            • May 2010
                            • 312
                            I was just about to to ask Trout to repost and low and behold he did!!
                              • 898
                              beautiful-I don't know which is easier for me solder or crimp pins-they say whatever turns your propellers-you obviously have yours turning max RPM and in sync (nice job)..I'll have to give it a try sometime
