Loosing up the dive the sail dive planes on the 1:72 Skipjack
  • Casey Thrower
    • Feb 2016
    • 8
    Seems like a lot of resistance in the sail dive planes. Grease or just hollow out the holes?
    • 13642
    Are the gear teeth too tight a mesh? Is the gear operating shaft too long, its ends rubbing tightly against the inside walls of the sail? are the bearing holes through which the sail plane operating shaft passes too tight?
    No grease!
    • Casey Thrower
      • Feb 2016
      • 8
      Seems the sail plane shafts are a bit too snug.
        • 13642
        Open up the bearing holes in the sides of the sail and you're good.
        • Casey Thrower
          • Feb 2016
          • 8
          I sent you another PM. Thanks.
            • 3670
            Casey, in the past, PMs did not work with David.
