David Merriman's Garage Sale
    Here's another one! A little gem!
    2.5" diameter
    23" long
    4" ballast tank
    3 pushrod seals
    Snort tubes in Motor bulkhead
    Gas servo installed. No Gas saver system.
    Equipment tray
    12volt 380 motor gear reduced RPM
    It was used for a 1/16th KAIRU
    And then, there's this -- It's the battery compartment forward end cap. We'll have to ask HWSNBN what it is. It has a 9volt battery to power it.
    But just in case it's a load of CR** I've put an ordinary end cap in with the kit.
    $150
      SOLD
      Ill Take one right now. Itll work on the UFO Skydiver. Im dialing the phone. One ringydingy.........two ringydingy
        • 13984
        #48
        [ATTACH=CONFIG]24648[/ATTACH]
        2.5" diameter
        23" long
        4" ballast tank
        3 pushrod seals
        Equipment tray
        [ATTACH=CONFIG]24647[/ATTACH]
        $150
        Oh, that! An early WTC I used on my Wallace 1/16 KAIRUY. The devices include a SubTech Depth-Keeper circuit, a BEC, and switch(s) with wateright boots.
          Folks
          I have a number of inquiries and I am struggling with answers sometimes because I simply do not know all the boats ballast sizes. So if you aren't sure what size you need, please ask the guys on the forum.
          Once I have an idea of the overall size you need, I can jiggle all this stuff around to make up whatever you need.
          Most of these units will be around half the normal price, and depending on what is inside them in the way of existing electronics, that will effect the price.
          I need to know-
          1. Diameter
          2. Overall length
          3. Ballast tank volume
          4. single or double motors
          • solosub
            • 51
            #50
            Hello :)
            Do you have a 1.25 SD with ballast ?
            Laurent
            www.scalesub.com
            French RC submarine forum
              • 13984
              #51
              Not yet.
ID:	89321Click image for larger version
ID:	89322Click image for larger version
ID:	89323Click image for larger version
ID:	89324Click image for larger version
ID:	89325Click image for larger version
              Working on it when time permits.
              • subkraft
                • Oct 2009
                • 28
                #52
                All turned up yesterday, all fine.
                And thankyou for extras.....
                Regards
                  Regards
                  Great! Post pics when it's all running please.
                  • subkraft
                    • Oct 2009
                    • 28
                    #54
                    Will do.....its a spot on fit for the Holland. Just a bit of dremelling....
                    • Bob C
                      • Mar 2010
                      • 5
                      #55
                      PM sent. Bob
                        1:96 Skipjack Sub-driver
                        2.5" diameter
                        16" long
                        Propel Gas Ballast - vent blow servo installed. Gas saver.
                        400 Graupner motor gearbox reduction built in motor bulkhead.
                        I have three of these. Can be easily modified to Snort. I'd put the Snort pump in with the battery and run the power back to the engine room through the connecting tube in the ballast tank.
                        $150 each
                        • crazygary
                          • Sep 2012
                          • 610
                          #57
                          Anything that'll fit a Trumpeter Kilo??
                          Just wondering!
                            Just wondering!
                            Yes
                            I have a brand new Sub-driver with Snort, LipoGuard, Sombra SL8 ch receiver, ADF Pitch Controller, Mtronics Speed Controller, Klik-ons Dog-bone connector, Propel Failsafe tank.
                            All you need is a battery and plug it in. This is ready to go.
                            Sub-driver kit = 375.00 + 50 to assemble and test
                            ADF 79.00
                            LipoGuard 50.00
                            Sombra SL 8 60.00
                            Snort. 57.00
                            Total $671 less 20% = $535
                            • subsailor
                              • Feb 2013
                              • 9
                              #59
                              Mike:Can not find 2.5" o-rings at sub-driver.com I thought you said their available.I may need some help where to look. Thanks Christopher P.S. W.T.C. is a great value you sold me!
                                Sorry, but I don't sell O rings. HWSNBN was going to give me some dimensions, because I ought to carry a few. The trouble is, it somewhat depends on the thickness of the tube, which varies from batch to batch.
                                Perhaps we should send out a set of three slightly different ones in an O ring kit?
                                Anyone else have any bright ideas?
