Large format 3D printer - Help me get it gone!
    UPDATE: Price drop! I've got no room for this in my poor shop and need it gone! Price dropped to clear it out! Full retail price is over $6k! Asking $750 plus shipping. Check out the listing and buy-it-now here: https://www.rc-submarine.com/product...-18-3d-printer This is my personal large-format 3D printer that I've used for printing the hulls of submarines amongst many, many other things.
    It's been a reliable printer for me over the years, but I'm letting it go for newer technology. The accordian-style gantry seal at the top was removed due to the adhesive coming loose, but I honestly never understood the point of it anyway. The only issue it has is the main power switch, which is behaving erratically. Five minutes and a $0.25 rocker switch will have that addressed. It still works now, but you sometimes need to rock it a few times to take power.
    Here are the technical specs I downloaded. Buyer responsible for confirming any specific details that are imperative to your efforts prior to purchase, as I cannot guarantee the accuracy of the specs provided. They are for guidance only.
    Makerbot has their own proprietary slicing software, which you can download for free. It is exceptionally easy to use and does result in very good prints.
    TECHNICAL SPECIFICATIONS
    PRINT TECHNOLOGY
    FUSED DEPOSITION MODELING
    BUILD VOLUME
    30.5 L X 30.5 W X 45.7 H CM
    [12.0 L X 12.0 W X 18.0 H IN]
    42,512 CUBIC CENTIMETERS
    [2,592 CUBIC INCHES]
    LAYER RESOLUTION
    100 MICRONS [0.0039 IN]
    FILAMENT DIAMETER
    1.75 MM [0.069 IN]
    FILAMENT COMPATIBILITY
    MAKERBOT PLA FILAMENT
    LARGE SPOOL
    0.9 KG [2.0 LB]
    NOZZLE DIAMETER
    0.4 MM [0.015 IN]
    PRINT FILE TYPE
    .MAKERBOT
    TEMPERATURE
    AMBIENT OPERATING TEMPERATURE
    15-24°C [60-75.2°F]
    STORAGE TEMPERATURE
    0-38°C [32-100°F]
    SIZE & WEIGHT
    SHIPPING WEIGHT(INCLUDES ACCESSORY KIT)
    52 KG [115 LBS]
    MECHANICAL
    MECHANICAL CONSTRUCTION
    POWDER-COATED STEEL WITH PC-ABS AND ALUMINUM COMPOSITE MATERIAL
    BUILD SURFACE
    INJECTION MOLDED PC-ABS
    STEPPER MOTORS
    1.8° STEP ANGLE WITH 1/16
    MICRO-STEPPING
    XY POSITIONING PRECISION
    11 MICRONS [0.0004 IN]
    Z POSITIONING PRECISION
    2.5 MICRONS [0.0001 IN]
    SOFTWARE
    SOFTWARE BUNDLE
    MAKERBOT PRINT
    MAKERBOT MOBILE
    SUPPORTED FILE TYPE
    STL, OBJ, THING, MAKERBOT
    OPERATING SYSTEMS
    WINDOWS (7+)
    MAC OS X (10.7+)
    LINUX (UBUNTU, FEDORA)
    ELECTRICAL
    POWER REQUIREMENTS
    100-240 V; 5.4-2.2 A;
    50/60 HZ; 350 W
    CONNECTIVITY
    WI-FI, USB, ETHERNET
    Due to the very large size, a shipping correction may need to be invoices, depending on your location. For an exact quote, please contact me in advance.
