Watertight box set up for R/C components
    • 1986
    This is an unfinished watertight box oriignally slated for use in a 1/8 scale ALVIN R/C submarine. It is based off of an Underwater Kinetics 408 Clear View UltraBox. Unit is completely new and unused with the clear protectant film still on the lid!
    • Internal Dimensions 7.9x4.7x2
    • 9.11 L x 5.9 W x 4.25 D inches
    • Submersible to 15 feet/5 meters
    • Automatic pressure equalization valve insures easy opening after altitude or temperature change
    This box is set up with:
    • an OTW drive unit with integrated seal
    • Mtroniks Viper 15 ESC
    • Two Futaba servos with linear conversion
    • bellows linkage seals
    • 2-pin waterproof output connector for lighting
    • 2-pin waterproof output connector for bow thruster or vertical thrusters
    • Twin connectors for a pump-based ballast system
    Parts alone add up to over $150.
    Order here: https://www.rc-submarine.com/product...3-a00010c5e28d
