This looks like a great choice for many sub applications.
Caswell sells an SL-6 that operates on 75 MHz and includes a CH 69 Crystal, which allows it to operate out of the box with the WFly T/R they sell.
I looked over the Sombra site for more info:
http://www.sombralabs.com/products.php
One thing I noticed is that the SL-6 is specified on the Sombra site as 72 MHz (as well as being available in HAM frequencies). 72 MHz is, as I understand it, allocated by the US FCC for air, but not for surface/subsurface use.
I assume that achieving 75 MHz operation is just a crystal issue for any Sombra SL-6 Lepton and that I could run any non-HAM SL-6 as either 72 MHz or 75 MHz depending on the installed crystal. (The photos on the Sombra and Caswell sites have SL-6s with "72 MHz" printed on the case.)
Enough with the assumptions...
Will the 72 MHz Lepton take a 75 MHz crystal and, if so, what kind?
Any advantages to the HAM version worth talking about?
The SL-8 and SL6 look like great products. I suspect I'll prefer SL-8s for their versatility, but I'm told there are some applications where there's only room for an SL-6. Any chance of getting a synthesized tuner on an SL-6 or smaller(!) receiver?
Finally, though we can't use 2.4 GHz underwater, any news on your 2.4 GHz systems?
