Will the Sombra work with a JR Propo Alpina PCM radio? On the back label it says 75M MHZ
Will a sombra sl-8 work with.............
Tags: None
Haven't any experience with that set, but all PCM sets I have encountered are switchable between PCM and normal PPM. JR use a different shift pattern to most other makes I think, but the Sombra is unlikely to worry about that. So provided your set is switchable, it should eb a problem.Comment
Nah, this is a inexpensive 2 channel pistol grip radio , designed for model cars. They stopped making it 20 years ago. But I still have and use two of them. Just wondering.IT TAKES GREAT INTELLIGENCE TO FAKE SUCH STUPIDITY!Comment
ya know, I have heard that the radio is fine but the receivers definetly need to go. I had soooo much trouble with it.IT TAKES GREAT INTELLIGENCE TO FAKE SUCH STUPIDITY!Comment
Must have been a really lousy PCM system then. Personally I use 2.4ghz system (Spektrum and Corona) for everything above the water, it's a quantum leap over the older systems, just too bad it doesn't cut through the wet stuff.Comment
Did you follow the instructions on how to bind the receiver to your radio? You can do it with the shadow programmer, or the bind plug.http://www.sombralabs.com/download/S...Guide%20V5.pdf Make sure that your WYFLY is on while you are doing it. Let us know.Last edited by greenman407; 10-18-2014, 08:34 PM.IT TAKES GREAT INTELLIGENCE TO FAKE SUCH STUPIDITY!Comment
I followed the protocol to the letter using the binding loop. It appeared to bind on two occasions, but when I touched the receiver to unplug the loop it immediately became unbound on both occasions. Personally I think there is something wrong with the receiver. Both the receiver and the radio have never been used before now. I acquired them a couple years ago when I built my gato sub, but didn't use them because I ordered a Wfly 8 channel because I needed 7 channels for the gato. Do you think a shadow programmer would work even though the loop doesn't?Comment
KMcKevin McLeod - Oscar II driver
KMc DesignsComment
Still can't get the receiver to bind again. Tried using a separate power switch but since it won't bind, unable to try the switch. I ordered a 6 channel Lepton receiver, but now I find I can't get a crystal for it. I tried Caliber Hobby but they are out of stock and it appears that GWS Systems may not even be in business from my further searching. Does anyone have a channel 69 crystal that will work in receiver that I just ordered? Getting Frustrated! HELP. TedComment
Hi Ted,
According to their website this place has stock on Ch 69 GWS crystals: http://www.robotmarketplace.com/prod...WX1R75570.htmlKevin McLeod - Oscar II driver
KMc DesignsComment
